How to cheat emmissions 101! It worked!
Old Nov 20, 2003 | 04:34 PM
chevy5143's Avatar
Thumbs up How to cheat emissions 101! It worked!
Allright guys well incase you haven't heard a buddy of mine with a cc306, LT's, Ported heads, 1.6rr went to get his emmissions done again and agian and after failing the for the third time.
My uncle and his hot rod buddies told us to hook up a compressed air tank and tape it into the exhaust before the cat/sniffer(duh) rig a switch connected to petal, then open up the tank and hope. They said the compressed O2 will change the mixture of expelled exhaust and flush out.
Here is the previous thread!
http://web.camaross.com/forums/showt...genumber=1went this afternoon
Well it worked we routed an a compressor hose from the tank under the carpet and out through a rubber plug under the passenger seat and taped it into the pipe right before the cat!
The test was in Georgia and it was a rolling smog w/sniffer on a 94z the NO2 had the biggest noticable diffrence which went from 1100 down 100 where 750 is passing
and CO went from 1.02 down to .42
Hope this might help some of you fellas. Now grumpygeezer(grumpygreaseape) or whoever can take a peak at redneck technology!
Old Nov 20, 2003 | 04:39 PM
Fuels94TA's Avatar
put some pics up i like to see how you hook this stuff up.
Vinny
Old Nov 20, 2003 | 04:46 PM
chevy5143's Avatar
I dont own a camera but the hardest part was hooking up a trigger to the pedal we gave up on it and decided to open the bottle (an old propane tank) a half of a turn before we got out of the car. Then we had to drill out a 1/2 inch hole for a quick release tip ( you know the end that you use to connect airtools to the line with, it has a collar that you pull down to hook them together) that we welded on to the pipe so it wouldn't be noticable.
Old Nov 20, 2003 | 05:30 PM
grendal's Avatar
I'd thought of this too....
Emissions tests work based on PERCENTAGE of emissions, not QUANTITY....
So, the more air that pumps out of your tail pipe, the better.... This is why a 8.0L engine can still pass with virtually the same numbers as a 2.0L engine. It's not quantity it's ratio/percentage....
So, if you can pump more clean air down the pipe along with the exhaust air, your percentage will go down, every time.
An easier idea might be rigging the AIR pump to run ALL THE TIME maybe via a switch?.... This would require very little modification of the car. Question is, would it be enough air to make a difference....
-Michael
Old Nov 20, 2003 | 05:32 PM
dnz28's Avatar
I told these people about it a while back and everyone didnt believe me.
Old Nov 20, 2003 | 05:34 PM
FacelessZ's Avatar
Re: How to cheat emmissions 101! It worked!
Great job! ...but for all that trouble you couldn't find someone with the hookup for an inspection sticker?
Old Nov 20, 2003 | 05:46 PM
chevy5143's Avatar
Re: Re: How to cheat emmissions 101! It worked!
Ya i probably could of but you know it was one of those i wonder if it could be done deals? So we went for it. Thanks for the support
Old Nov 20, 2003 | 06:04 PM
N2OpwrdTA's Avatar
Thumbs up
This is good info. Maybe you should fix the spelling of emissions in your title so this will come up in a search "titles only search" in the future for other people.
Old Nov 24, 2003 | 07:37 AM
TheHeadFL's Avatar
Doesn't fresh air help the cats work more efficiently?
Old Nov 24, 2003 | 01:53 PM
chevy5143's Avatar
ya that is what i was told and why to place it before the cats to help with a complete burn. But it was also to work on the percentages/ratio of other emissions components.
Old Nov 24, 2003 | 05:56 PM
Procharger's Avatar
here the trick i did after failing 10 times. tryed timing/vacumhoses/denatured alchol/even put my stock injectors in.. still failed..So i thought about it for a sec.. let me try something stupid.. i un hooked 2 injectors and let it run on 6 cylinders.. guess what passed with flying colors.. after i got the paper in my hand pulled the car out of the bay and hooked up the 2 injectors and laughed my a$$ off.. the next year they stopped doing emission testing in our county..
Old Nov 24, 2003 | 06:20 PM
Cahill93Z's Avatar
hell ya!
Old Nov 24, 2003 | 06:23 PM
SSlammedlt-4's Avatar
Im glad we dont have emission tests here in the heart of America. I love running no cats and no egr. it great, not having to worry if I am going to pass the mext test.
L8
Shawn
Old Nov 24, 2003 | 06:30 PM
95 Z/28 LT1's Avatar
Super Moderator
Done!
Old Nov 24, 2003 | 06:54 PM
BlackLT1_TX's Avatar
L8
Shawn
i can only imagine, i live in dfw, rolling smog test every year, and random emissions testing units on random offramps ready to sniff you as you drive over them, if you are above the limit it snaps a photo and then you find a notice that you have to get your car reinspected within so many days or something. it sucks, made me put my cat back on
if i get a cam or headers i'll pull it off, just wasnt enough hp to run without it.
