how to change a?
Old May 27, 2004 | 04:56 PM
TrouserSnake's Avatar
how to change a?
Injector with out pulling all the injectors out can it be done?
Im having a rough time understanding this little mechinizm
Old May 27, 2004 | 04:59 PM
Pasky's Avatar
LOL, very very easy, just pull the fuel rail, its 4 bolts and thier visible on top of the intake. Pull those four and the rail along with the injectors come up allowing you to replace it very easily.
Old May 27, 2004 | 05:00 PM
simple's Avatar
if it is #1#2#8#7 injector then you might be able to pull it out without pulling all of them up
regardless tho the rail will need to be lifted from the intake
4 bolts on top need unscrewed then lift up on the rails
Old May 27, 2004 | 05:21 PM
scoobysnax83's Avatar
think of it this way. If you had started already you'd be done....
Old May 27, 2004 | 05:22 PM
simple's Avatar
LOL no ****
96SilverRam
Nov 20, 2016 11:19 AM
jayblev95
Jun 7, 2015 04:04 PM
mdenz3
May 22, 2015 09:25 AM
May 1, 2015 01:14 PM
NewsBot
Jan 21, 2015 06:10 PM
