how can you tell if your rear is bent?
Old Apr 30, 2003 | 10:46 PM
chasmanz28's Avatar
Red face how can you tell if your rear axle is bent?
can you bend your rear axle from being heavy on the pedal? mostly a stock car, couple of bolt on's im curious
Old Apr 30, 2003 | 11:01 PM
96speed's Avatar
Question
Bend your rear? Bend an axle maybe?
Sounds like someone has been wathcing too much fast and furious and decided to give tech advice .
What are your symptoms?
Ryan
Old Apr 30, 2003 | 11:06 PM
chasmanz28's Avatar
Ryan
well had my car on the lift and those bumpers guards on top of each axle by the wheel, i forget the name, anyways the right wheel has maybe 2 inch clearance, or gap before it would hit the tire, but the left wheel is real close to that bumper guard, doesnt look right, thats what got me thinking maybe i bent the axle somehow, the swaybar looks fine, nothing looks bent, just dont know, is there a way i can see if its out, without having to go to an body shop
Old Apr 30, 2003 | 11:09 PM
96speed's Avatar
Its not uncommon (especially for aftermarket) springs to be off. If an axle was bent, you'd likely feel some vibrations. You can buy rubber coil spacers to "space out" a coil on the shorter spring.
Ryan
Old Apr 30, 2003 | 11:16 PM
chasmanz28's Avatar
Ryan
you mean if the springs are weak it would throw the axle out of wack, it doesnt vibrate, tires arent wearing, car doesnt sag to one side, but it looks like the left side is pushed toward the front just a tad from what the spacing looks like from the guards on the axle, i got a tape measure and went from hub to hub on each side, the right side was 101 1/4 and the left side was almost 102 is that normal
Old Apr 30, 2003 | 11:27 PM
96speed's Avatar
Ok...I think I'm reading you now...
It sounds like you panhard rod isn't centering (laterally) the rearend properly. Is the car lowered at all? It is normal for the car to "shift" to one side when lowered. An adjustable panhard rod will fix this.
If it isn';t lowered, it seems strange that it would off to one side, but an adjustable panhard rod could still fix it - assuming I am following you.
hope this helps,
Ryan
Old Apr 30, 2003 | 11:30 PM
chasmanz28's Avatar
hope this helps,
Ryan
no the car isnt lowered, like i said i never knew i had a problem until today by looking at the gap difffence between each guard
Old May 1, 2003 | 12:01 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
CAPTAIN OBVIOUS... AND HIS INFAMOUS SIDEKICK, FRMULA... ARE ABOUT TO SPEAK...
captain obvious says think back to the great san francisco earthquake of 1847... now... imagine all of that JUST in the cabin of your car...
this is what it would be like to have a "bent" axle...
captain obvious has spoken
captain obvious has left the forum
captain obvious will be here all week, be sure to tip your waitress
Old May 1, 2003 | 12:03 AM
chasmanz28's Avatar
captain you drinking?
HarleyZ28
Oct 5, 2015 06:23 AM
Ken Cemo
Mar 31, 2015 08:50 AM
BPS
9
Mar 5, 2015 10:51 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Roadie
Feb 16, 2015 10:34 AM
