how can you tell if your icm is goneing bad
Old 10-11-2003, 06:40 PM
shootcallerz28's Avatar
To day my car died when i tried to crank it back up it back fires and gauges went crazy go it started drove home easy and when i got home it home and cut it off same problem so i thought it was the coil i replace it .still same problem car crank up but took it down the road and it start to run rough i have a brand new opti from gm that i had put on about 6 mouths ago could it be my ICM or what need help thanks.
shootcallerz28 is offline
Old 10-11-2003, 07:39 PM
Seal's Avatar
i'd love to help, but i didnt understand a single thing other than u got home and ur car died, and u changed the coil...
Seal is offline
Old 10-11-2003, 07:42 PM
mPoRtSsUcK's Avatar
danm dude, may want to learn to speak and type proper before you do any work on a car. i barely understood what that said. try checking your plugs to see how they are.
mPoRtSsUcK is offline
Old 10-11-2003, 08:03 PM
AustinZ28's Avatar
Holy crap, that was the hardest thing to comprehend. What the hell are you talking about? Thanks for the headache
AustinZ28 is offline
Old 10-11-2003, 09:08 PM
94GrayV6's Avatar
When my ICM went I was going down the highway and the car just died. It would crank, but wouldn't fire.
94GrayV6 is offline
kallcium
V6 Tech
10-07-2015 03:39 PM
Critter
07-07-2015 08:33 PM
ad356
04-11-2015 11:12 PM
Blood type Z28
04-08-2015 11:34 PM
USAirman93
11-24-2014 03:37 PM
Quick Reply: how can you tell if your icm is goneing bad
