How can swap to a carb intake on my 95 z28 camaro it has a stock lt1
Old Dec 4, 2009 | 07:53 AM
faroncruz95z28's Avatar
How can swap to a carb intake on my 95 z28 camaro it has a stock lt1 please help thanks
Old Dec 4, 2009 | 04:01 PM
Yes. GM Performance Parts made a carb intake for the LT1. You can use a conventional distributor as well.... just have to squeeze it under the cowl.
Old Dec 4, 2009 | 04:42 PM
dsmawd350's Avatar
GMPP makes a dual plane carb intake for the LTx. If you wan tto go single plane you have to have the LT1 bolt pattern drilled in a SBC manifold
Old Dec 5, 2009 | 11:51 PM
Thanks alot
Old Dec 10, 2009 | 07:13 PM
z275plus's Avatar
Does anyone have a parts list or pix of this set-up ?
Old Dec 10, 2009 | 09:09 PM
SnakeOiler's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=725941
Old Dec 11, 2009 | 06:27 PM
Jameslt1TA's Avatar
Something esle you may want to find out is if a carb will fit under a stock hood or not. I really have no idea although i would think that it would be a pretty tight fit if it would.
Brandon Wittmer
Dec 3, 2014 09:28 PM
thenewkid
Nov 27, 2014 09:41 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
jwright3SS
Jul 30, 2002 03:49 PM
