How can i tell if my engine is stroked?
Old May 28, 2008 | 12:40 AM
lt1stroker's Avatar
Hello, many of you have seen my posts in the lt1/lt4 threads about me making a dumb decision in buying a 96 z28 camaro with supposebly a 383 stroker with no papers. i need to know what steps i can make in finding out if the engine is indeed stroked? Thanks
Old May 28, 2008 | 02:39 AM
MasterZ28's Avatar
The only way to make sure is to take it in to measure the stroke (piston travel) at a shop. UNLESS, you know what it's supposed to sound like stroked or some noticable features I may not know about until someone can pitch in.
Old May 28, 2008 | 07:34 AM
AL SS590 M6's Avatar
Moderator
I know that in some cu.in. restricted race classes they pump the motor to catch cheaters. So there is equipment out there that can determine cuibic inches without tearing it down.
Old May 28, 2008 | 12:04 PM
Z28SORR's Avatar
You can usually tell when an engine has been disassembled. Maybe you should tell us WHY you think you do not have a 383.
Old May 28, 2008 | 12:52 PM
lt1stroker's Avatar
^ Because he didnt have any papers. but i mean the car pulls alot, i can tell that but not sure if the engine has been stroked. What kind of shop can tell me if the engine has been stroked?
Old May 28, 2008 | 03:37 PM
mdacton's Avatar
take a air hose adapter and get the cyl to BDC then cc the cyl with antifreeze and do it quick b/c its going to run in the oil.
You could try trans fluid too.
Old May 29, 2008 | 11:13 AM
Mikey97Z's Avatar
Check the computer's displacement setting with LT1 Edit!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
transam_388
Mar 15, 2015 11:53 AM
squirrels
Jul 13, 2002 01:58 AM
