how can i get better throttle response????
Old Aug 11, 2005 | 01:36 PM
jamilz28's Avatar
Old Aug 11, 2005 | 01:40 PM
TobyZ28's Avatar
Re: how can i get better throttle response????
Clean or Replace MAF if its old / dirty
Clean IAC Valve and passages in the TB
Seafoam the intake
Install a CAI
Old Aug 11, 2005 | 01:41 PM
speed_demon24's Avatar
A bigger throttle body is the best way to get better throttle response. the bigger it is, the better the throttle response is.
Old Aug 11, 2005 | 01:43 PM
hotazzz28's Avatar
Will these things contribute to rough idle as well?
Old Aug 11, 2005 | 01:44 PM
jamilz28's Avatar
i have heard that a tb on stock car loses hp
Old Aug 11, 2005 | 01:45 PM
TobyZ28's Avatar
My suggestions will only help the idle.
Goign to a bigger TB shouldnt hurt idle, but some brands people have noted idle issues later, most of which eventually are resolved once they figure out what was causing hte higher idle.
Old Aug 11, 2005 | 01:46 PM
diehardgm's Avatar
Several things will help. First off, throttle respose comes from the ability to get air in and out of the engine quicker and more efficiently. That being said, small things like a CAI, Catback, high-flow or no cat, headers are a good place to start. Be sure the car is running the best it can in stock form first, meaning good plugs, o2 sensors, etc. Obviously if you want the most from it, go with heads and cam, larger injectors, and a good program from pcmforless.
Old Aug 11, 2005 | 01:49 PM
jamilz28's Avatar
i swaped my flowmaster with a dynomax bullet and it helped alot
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
tommalcolm
Sep 11, 2015 03:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
