How can I force open loop
Old Oct 14, 2004 | 12:39 PM
  #16
93 RED Z's Avatar
Re: How can I force open loop
Originally Posted by david97gsxr
also, if you have a DVOM, you could find out what the resistance is of the sensor when you first start the car. and then solder in some resistors to make it read that resistance when the car is warmed up....
if you wanted to go that route.
Yea I passed, the tester tested it this AM cold=open loop and with about 30% Alcohol it passed, with 0.37 CO's down from 1.5 to1.6....
I also desided that I will do the resistor thing (thanks for the suggestion) with the water sensor next time so that I don't have to have the test done cold. By the way here in Colorado we already run 10% Alcohol from the pump so another 20% was more than I needed. I've already run out the fuel mixture and everything is back to normal. As close as I ever am to normal.
THANKS FOR THE HELP GUY'S!!!!!!!!!!!
Old Oct 14, 2004 | 12:56 PM
  #17
mojorisin's Avatar
someone may need to verify, but i think you can put some sort of a resistor in the iat sensor???
Old Oct 14, 2004 | 01:14 PM
  #18
93 RED Z's Avatar
ImNraged
Aug 19, 2018 08:02 PM
Quickss96
Jan 29, 2016 05:56 PM
Bails098
Aug 17, 2015 05:15 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
