How can I force open loop
Re: How can I force open loop
Originally Posted by david97gsxr
also, if you have a DVOM, you could find out what the resistance is of the sensor when you first start the car. and then solder in some resistors to make it read that resistance when the car is warmed up....
if you wanted to go that route.
I also desided that I will do the resistor thing (thanks for the suggestion) with the water sensor next time so that I don't have to have the test done cold. By the way here in Colorado we already run 10% Alcohol from the pump so another 20% was more than I needed. I've already run out the fuel mixture and everything is back to normal. As close as I ever am to normal.
THANKS FOR THE HELP GUY'S!!!!!!!!!!!
Bails098
Aug 17, 2015 05:15 PM
