How can I force open loop
Old Oct 13, 2004 | 08:46 AM
93 RED Z's Avatar
How can I force my Z to stay in open loop? I'm trying something with emissions. Thanks.....
Old Oct 13, 2004 | 09:07 AM
ChrisS95TA's Avatar
Re: How can I force open loop
Pull the AIR fuse and set an SES light? I think with SES light it stays in open loop and the fans turn on.
EDIT:
Cant pass inspection with SES light on, atleast in NJ, so that might defeat the purpose...duh stoopid me
Old Oct 13, 2004 | 09:17 AM
93 RED Z's Avatar
Ha thanks but I should have stated (and not with an SES light). Yep emissions inspectors don't like SES lights on. But thanks anyway.
Old Oct 13, 2004 | 09:30 AM
PatriotTA's Avatar
The easiest way to stay in open loop would be to unplug your O2 sensors, but that would set the SES light. Not sure what you are trying to do, since your car makes the least emmissions in closed loop, after everything is warmed up.
Old Oct 13, 2004 | 10:14 AM
93 RED Z's Avatar
Yes like ya said that would have the SES light on also. I just need a way to (temporarily), just long enough to get the emission test done, to stay in open loop. I'm going to try and run a fuel mixture to lower my CO's just during the test and 10 min. later change back. The tester is working with me a little. I might even get the tester to run the test while engine is cold, which would do it, but would like to keep him out of the loop as much as possible. Don't even want to go near the $50/$100 under the table thing. I'm also thinking of unplugging an injector while in open loop. Just a thought.
Old Oct 13, 2004 | 01:09 PM
atljar's Avatar
Go into your constant tables in tunercats. Set minimum coolant temperature really high in order to enable closed loop. No codes.
Old Oct 13, 2004 | 01:23 PM
WS Sick's Avatar
We did this on our 93 and it never threw a light.
Old Oct 13, 2004 | 01:29 PM
93 RED Z's Avatar
Now that don't sound like something that I'm going to do with a screw driver/hammer.. LOL .. All I've got is an Autoxray for sensor/computer display, nothing to change stuff with. Is there nothing I can do (unplug/jumper), to force it?
Thanks alot for the help! I'm going to try and get this done this evening.....
Old Oct 13, 2004 | 02:07 PM
WhiteSSP's Avatar
do everything that everyone said to get it into open loop, then take out the SES light bulb. Voila, no SES and in open loop, all with nothing but hand tools.
Old Oct 13, 2004 | 02:26 PM
93 RED Z's Avatar
But as you are well aware I'm sure, the tester execpts a light when the key is turned to just the on position.
WS SICK -- I'll try the unplugged O2 when I get home.
Sure hope it works, THANKS for all the help!
Old Oct 13, 2004 | 02:38 PM
david97gsxr's Avatar
couldn't you unplug the coolant sensor from the water pump and plug it up?
that way the sensor never sees about 145* or whatever our cars go into closed loop at.
the thermostat would still work, and i don't know which sensor controls the fans, the one in the water pump or the one in the head, but if it's the one in the water pump, just make a jumper wire going to the white(power) wire of the fans, to a 12v source. then the fan will be on all the time, so you don't have to worry about overheating.
Old Oct 13, 2004 | 02:59 PM
93 RED Z's Avatar
I already have a switch for my fans but if I just pull the temp connector and eather jumper or leave it open, do you know if the will through a code or SES light. Thanks..
Old Oct 13, 2004 | 07:20 PM
WhiteSSP's Avatar
Ah, didnt know that. We dont have emissions here (thank god), so i was just making a guess. Well best of luck to you.
Old Oct 13, 2004 | 07:26 PM
i wouldn't think it would if you just pull the sensor out of the the water pump. it's not like it has to be emerged in coolant. if you unplug the wires, or disconnect the sensor terminals/connector, it WILL throw a code. it needs to have a closed circuit or it will throw a code.
so, you'd need to pull the entire sensor out. and plug the hole with a pipe plug.
the only issue would be, you'd have to keep the sensor away from heat, if you just leave it dangling and under your hood temps reach 145, it will go into closed loop.
Old Oct 13, 2004 | 07:32 PM
also, if you have a DVOM, you could find out what the resistance is of the sensor when you first start the car. and then solder in some resistors to make it read that resistance when the car is warmed up....
if you wanted to go that route.
