How can I clean SVO injectors at home?
Old Nov 26, 2004 | 10:49 PM
T/A#4's Avatar
They are out of the motor & I'd like to clean them, any ideas ?
Old Nov 26, 2004 | 11:11 PM
zx1216's Avatar
Re: How can I clean SVO injectors at home?
I don't really know how you would clean them but it is damn expensive to have them cleaned, last time i checked it was like $20 an injector, i said no thanks, i imagine they hook them up and flow some solvent through them.
Old Nov 26, 2004 | 11:22 PM
guitarguy12309's Avatar
www.witchhunter.com does them for 12 bucks a piece and they include a flow sheet and everything...i got mine done and it was woooooooorlds of difference...he's a really good guy and gets your questions answered as fast as possible
hope this helps
adam
Old Nov 26, 2004 | 11:32 PM
zx1216's Avatar
Wow, i looked over the process and no wonder it is a bit pricy, looks like that shop does a good job, i will probably just wait untill i need bigger injectors which i hope will be soon
Old Nov 27, 2004 | 09:34 AM
96capricemgr's Avatar
There is a place just west of Appleton that does them for $10 apiece, I had them do a set for me I was happy with the work BUT they found the set to vary flow wise and one was totally dead so I ended up buying a set even after having one set cleaned. Shoot me a PM if you plan to go to WIR one noght once they reopen, or maybe even if you have a major mod you need a hand with.
Old Nov 27, 2004 | 09:54 AM
T/A#4's Avatar
Thanks for the info fellas. Looks like my buying a used set of injectors wasn't such a good idea after all
30# SVO injt. used $130. .....Clean @ $12 each $96, plus shipping 2X $24.
Total $250.
New ................... $210.
Old Nov 27, 2004 | 10:10 AM
You could always install them with programming and use a good fuel system treatment like Fuel Power or maybe Techron.
Old Nov 27, 2004 | 12:52 PM
DiabloGT's Avatar
Total $250.
where can you buy the new for $210?
Old Nov 27, 2004 | 03:19 PM
I think I have seen them in Summit for $220 so somewhere having them for $210 seams within the realm of possibility.
Old Nov 27, 2004 | 11:59 PM
T/A#4's Avatar
There is a FORD Hi Po site that has them for $200. Can't recall the name but it's around.
SC97TA
Sep 15, 2002 01:10 AM
rje
Sep 9, 2002 12:35 PM
Wilson
Jul 21, 2002 05:08 PM
