How can I adjust my idle?
Old Jan 9, 2004 | 02:38 PM
gamecockfan04's Avatar
Question How can I adjust my idle?
I have the famed "stumble at idle" and have discovered that if I hold the brake and give it a little gas and raise the rpm to about 800-900 it runs smoothly. So is there an easy way to adjust the idle, or is this caused maybe by a bad IAC? Also I tried adjusting the Idle with the TPS and that didnt work very good.
Old Jan 9, 2004 | 02:52 PM
96ZRDR's Avatar
Tuning! It is the only correct way.
Old Jan 11, 2004 | 07:16 AM
slopokrodrigez's Avatar
Could either be IAC problem such as carbon build up on the pintle or it could be the same problem with the EGR. Both should be cleaned and or replaced and don't forget a new gasket while your there.
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
edman
Jan 25, 2015 02:41 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
