70% TPS? Cable stretched?
Old Jan 10, 2004 | 10:05 PM
RMC's Avatar
RMC
Has anyone heard of the throttle cable stretching out? I scanned and was only getting 70% throttle even though I was mashing it to the floor. It's a '94 with a lot of miles do you suppose that's what happened?
I just put in a new TPS sensorto freshen some things up, but the old one wasn't getting up to 100% throttle either.
Did I maybe put it in wrong? What do you all think?
Old Jan 10, 2004 | 10:09 PM
OBE1 95Z28's Avatar
What's your TPS read when the blades are closed? Should be about .5V; are the holes slotted on the TPS housing? You may need to change the position of the TPS to get full range.
Old Jan 10, 2004 | 10:24 PM
zuluman13's Avatar
how do you check to see if it is registering at 100 percent?
Old Jan 10, 2004 | 10:52 PM
RMC's Avatar
RMC
I used datamaster to scan it both times.
With it just sitting there closed it's at 0.7V.
It's not slotted either it's brand new.
Old Jan 10, 2004 | 11:42 PM
Move the throttle lever at the TB by hand and watch your Datamaster display. This should help tell you if it is a cable problem. The engine does not have to be running, just have the key ON, so Datamaster can read what the pcm is seeing.
Old Jan 11, 2004 | 02:41 AM
RMC's Avatar
RMC
I was thinking about doing that, but it was already a little late in the evening for that. I'll get to it tomorrow and post if I can't make sense of the findings.
Thanks,
Ross
Old Jan 11, 2004 | 07:42 AM
97FormulaWS-6's Avatar
I have heard of the cable stretching, so if you find out that's the case you really have 2 replacement options.
1. Stocker; un-adjustable piece though, costs ~$15
2. Lokar; adjustable, Billet/Stainless, Costs ~$40
I'm running the Lokar unit, I broke the stocker, and am of the mindset if you have to replace it anyways, upgrade...
Old Jan 11, 2004 | 07:46 AM
AxeGrinder30thZ's Avatar
Yes, they can stretch. How do I know? Cause I have the WORST hesitation ever in my car because of it. You can start pulling the cable manually and it takes a little more pulling than normal to begin to rev up. I purchased another stocker but if that one ever stretches too, then I'll go to the Lokar.
Novo
Jun 14, 2016 02:58 AM
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
