how to calibrate 93 speedo
Old Feb 10, 2004 | 07:19 PM
speedracer93z28's Avatar
i have a 93 z28 with 3.73s and 17/40/255 wheels and tires, how do i calibrate my speedo to accomdate for these. thanks
Old Feb 10, 2004 | 07:30 PM
FlyboyZ28's Avatar
i also have 3.73's but i will have 315 35 r 17's on the back. Can anyone help
Dan
Old Feb 10, 2004 | 07:31 PM
snake_skinner93's Avatar
Either send your PCM off and have it programmed or if you have an A4 tranny, you can buy the set of plastic gears for the transmission and that should do the trick.
Old Feb 10, 2004 | 07:34 PM
FlyboyZ28's Avatar
I may be wrong, but i always thought that your couldnt do a 93 speedo calibration w/ the computer.
Old Feb 10, 2004 | 07:53 PM
TRIPLE G's Avatar
i believe if you have a manual you can get the PCM reprogramed for the 3.73 gears. If you have a auto you have to change the drive and driven gears.
GM p/n 25513052 (45 tooth driven gear) $12.78
GM p/n 8642820 (15 tooth drive gear) $7.56
These are the part numbers to correct the speedo for 3.73 gears in a auto but a local dealer told me they were out of production.
Old Feb 10, 2004 | 10:50 PM
Dan K's Avatar
I've screwed with 93's enough to know that it is possible to adjust the speedo in the computer.
But how everything relates to each other is beyond me. Wish I had a 93 so that I could keep working on it.
Old Feb 10, 2004 | 11:08 PM
stik6shift93's Avatar
Anybody now what gear's i need to recalibrate an m6 that went from 3.23s to 4.10s, it's a 93 of course.
Old Feb 10, 2004 | 11:14 PM
93TA's Avatar
for an auto, the easiest way is to buy the speedo gears(only works for autos), but for a stick the easiest way is to buy slp's calibration box(will work with auto or stick but it's more expensive than speedo gears), has several dip switches in it, that can be set in combinations to match most any gear/tire combo, it installs inline with the vss. and whatever you do.. do not buy the cyberdyne speedo calibration box(its junk for 93's your speedo will drop to 0 after about 85mph)
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
LazyLemming
Aug 29, 2015 07:36 PM
4586
Aug 24, 2015 11:04 PM
