how to build a steam tube????
Old Dec 4, 2009 | 10:15 PM
StangCrusher350's Avatar
hey guys. broke that sorry piece of metal they call a steam tube. wanted to build some maybe outta some RUSSELL pipe rope. any ideas and help on easiest way to build this would be much appreciated
Old Dec 5, 2009 | 06:38 AM
Guest47904's Avatar
Guest
That would be more like trying to build a pencil
If I remember correctly, the heads are 1/4 NPT. 2 right angle fittings and the braided line you spoke of should do it.
But isn't getting the pieces and then building this thing kinda like trying to build a pencil. These things are a dime a dozen at junk yards.
Parts:
http://www.summitracing.com/parts/SUM-220651/
http://www.summitracing.com/parts/RUS-660570/ not sure about this one check with supplier first
http://www.summitracing.com/parts/SUM-230620/
Old Dec 5, 2009 | 08:32 AM
maverickmk's Avatar
Or you can buy one from gmpartsdirect.com
1993-94 10108635 - $46.57
1995-97 12556260 - $78.00
Not sure what the difference is between the two, other than the price of course.
Old Dec 5, 2009 | 08:41 AM
WOW nevermind i just saw the price of that tubing... ill get one for 46 dollars and be careful with it. the reason i wanted to build one is because i couldn't find one for under 170.00
Old Dec 5, 2009 | 08:46 AM
also maverick, i also have the cc 503. any recommendations on which set of rockers and springs i should get
Old Dec 5, 2009 | 01:43 PM
maverickmk's Avatar
I used Comp Cams Beehive Springs pn 26918-16, Comp Cams Spring locators pn 4705-16, Comp Cams 11/32 10 Degree Machine Steel Locks pn 614-16 and Comp Cams 10 degree Steel Retainer pn 795-16. These are the recommended springs for this cam by Comp.
You will find that there is a lot of controversy surrounding the Comp Beehive springs on this board, I returned my original set to Comp & they sent me another set for free (that was a little over year ago) and I feel they have worked out all the problems they were having with them since. I've had no problems with them, and I've also read here that PAC springs are an excellent alternative. I used GMPP 5/16” Guide plates pn NAL-14011051. I used Comp Cams 1.6 full roller rockers.
Old Dec 5, 2009 | 03:03 PM
NightShadeZ28's Avatar
Check out these springs and rockers:
https://www.patriot-performance.com/...&cat=52&page=2
http://www.summitracing.com/parts/SUM-G6921B/
They both were recommended to me by Lloyd Elliot and I have not had a problem out of them. The springs and rockers are much cheaper (Only in price not quality IMO) and the rockers are quieter than the comp pro mags I had.
Old Dec 5, 2009 | 09:14 PM
thanks nightshade i think i will get these sets. i trust ALL of you know what you are doing. i can rip an engine apart and put it together correctly, but i dont know the correct way to install some things are. you guys really help me keep money in my empty wallet. it's pretty bad when i have to have my wife pay to fix MY Z but these rocker arms say they are 7/16''. i was told the ones on my 94 were like 3/8''
Old Dec 6, 2009 | 02:36 PM
JAKEJR's Avatar
Since the arms you're looking at at 7/16" you'll need to replace your stock rocker studs with 7/16" versions. ARPs are my recommendation.
They're easy to swap and are a direct replacement. Torque the new ones to 50#.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 6, 2009 | 04:50 PM
96 Z 28's Avatar
I think these are the same Roller Rocker Arms 3/8" except in the 3/8" Size
Old Dec 7, 2009 | 06:59 AM
thanks 96! now i don't have to spend even more cash
Old Dec 7, 2009 | 05:06 PM
96 z 28 is correct but I highly recommend upgrading your rocker arm studs even if they are 3/8 instead of 7/16. I don't know how old your stock ones are but I know they are not really made to hold the load of the new spring and rocker. I would suggest some arp 3/8 or 7/16 but I would go with the 7/16 to be worry free. If you go 7/16 you need 7/16 rockers. It is not really that much more ($40.00). And DO NOT forget the guideplates and new chromoly pushrods (Stock pushrods will not work. I recommend GM guideplates (Comp does not line up properly) and you can get them for $40.00 and I recommend Trick Flow chromoly pushrods and you can get these for $87.00 with just about any size needed and these prices are from Summit.
Old Dec 8, 2009 | 07:59 AM
DAVE00's Avatar
If you still need a steampipe, this guy over at ls1tech has one for $5. Just thought you might be interested:
http://www.ls1tech.com/forums/non-ls...lt1-parts.html
Old Dec 8, 2009 | 08:06 AM
bw_hunter's Avatar
Exclamation
Hi Folks,
I'm not a moderator and really don't have any right to say this but I'd like to recommend that we keep to one subject per thread. It makes it easier to search the archives for those of us that actually use the search function. The two subjects in this thread are both valid and each could support it's own thread.
Just my opinion, of course, and feel free to flame me if you like....
Old Dec 8, 2009 | 03:15 PM
Originally Posted by bw_hunter
Hi Folks,
Exactly what I've been thinking as this thing grew a second head.
