How big of a difference between ported LT1 and LT4 heads?
Old Dec 31, 2005 | 01:52 AM
HardcoreRM125's Avatar
How big of a difference is there, on average, between flow numbers on hogged out sets of heads?
Like say, LE3 versus a comparable port job on LT4 heads?
I heard LT1 heads have more room for port work, but LT4 heads flow alot better in stock form. For a heavily modified car, is it worth it to convert to LT4 heads and intake that are ported versus LT1 set up? Just wondering. I dont have the money yet for this jump into the project yet, but it just has been on my mind lately since my friend just bought a LT4 Vette
Old Dec 31, 2005 | 03:20 AM
1racerdude's Avatar
Re: How big of a difference between ported LT1 and LT4 heads?
About 20-25CFM.
If ya got a big engine go with AFR 227's.
Old Dec 31, 2005 | 05:42 PM
93 4mula's Avatar
Big engine as in 383/396?
Originally Posted by 1racerdude
About 20-25CFM.
Old Dec 31, 2005 | 08:30 PM
1racerdude's Avatar
YES & 406-421-434-454
Old Jan 1, 2006 | 11:04 AM
I wonder how they would be on an 383 low compression supercharged motor. This is what I want to one day do with my camaro once I get the money. Make a low comp 383 supercharged street car.
Old Jan 1, 2006 | 11:07 AM
flyinZ's Avatar
Would it be worth it, to put those AFR 227's on, if your still running an LT1 intake?? Granted the intake has been ported,material removed/welded above the injectors,etc...Would that intake choke those big heads??
Old Jan 1, 2006 | 11:24 AM
Boosted_Z28's Avatar
Unfortunately the AFR 227 heads are considered "LT-4" style and MUST be used with an LT-4 intake. I believe that the only AFR head that works with the LT-1 intake is their 180cc runner head.
Old Jan 1, 2006 | 12:13 PM
I just cheched out their site, that is apparently the only LT1 head they make, so you would have to switch to an LT4 intake too to run any of their other head set ups.
I really wonder how these heads would be for a forced induction 383 street car.
Old Jan 1, 2006 | 01:18 PM
roguedriver's Avatar
I'm getting a 9:1 383 LT1 long block done up now. It's gonna be running 10psi with a 100 to 150 shot on top of that. I stuck with a nice set of ported LT1 heads. I'm sure I wouldn't outflow a done up LT4 head, but they would probably come close. Bang for the buck though and if your not worried about squeezing every ounce of horsepower out of your setup, I think the LT1's are a nice setup. My dyno numbers will somewhat tell the story though and then the track.
Ken R.
Old Jan 1, 2006 | 02:13 PM
RogueDriver: That is almost exactly the kind of set up I want to build. Could you PM me and let me know more about the project. Im really interested in the head/cam you have set up for it. And Id love to see the numbers it puts down w and w/o the spray
Old Jan 1, 2006 | 02:47 PM
2QUIK6's Avatar
I have a set of LE2 heads that are a LT1 casting but for the LT4 intake with 2.0/1.56 valves that flowed 274.4/185.6 at .550 and 272.4/190.9 at .600.
These heads along with a GTP6 236/242 and .597/.583 lift cam with 114 lsa produced 446rwhp N/A on a 383 motor.
So the LT1 castings can be made to flow exceptionly well, I'd think the difference for a SC/turbo application would be nil since your forcing air into the cylinder anyway as long as the boost in the intake is making it fully into the cylinders, it it ain't, then crank up the boost
Old Jan 1, 2006 | 04:15 PM
Mindgame's Avatar
Flow the intake after working it and see. If the intake flows less than the heads, you'll see a loss proportional to the difference. If you can get it to flow the same or 5% more, then youre sitting real good but that's probably not going to happen with a 227 at full potential.
-Mindgame
Old Jan 2, 2006 | 07:31 PM
DiabloGT's Avatar
what happens if the head is too big like a fully ported afr 227 on a stock crank?
Old Jan 2, 2006 | 07:38 PM
1racerdude's Avatar
It won't be too big.
Old Jan 2, 2006 | 09:26 PM
flyinZ's Avatar
-Mindgame
Well, Jordan Musser did the intake(LTx version)so, Im sure that thing will flow. Now, the current worked heads that are on it, could be a different story..Care to see the flow #'s for them? Or take this to PM's? Im curious..
Adam
