How big of a cam????????
Old Jan 29, 2003 | 09:35 AM
LALT1's Avatar
can I run without changing Valve springs. I have intentions of a stroker for next winter so i'm just wanting to do a cam to get me by this summer.
Old Jan 29, 2003 | 01:21 PM
'94 Bad A Z28's Avatar
Re: How big of a cam????????
STOCK! If you change to any cam, I don't care if it is smaller than stock, you are going to want to change valvesprings, unless that is something that you have done recently... You don't want to put a cam in without changing valvesprings, that is a big no no.
Old Jan 29, 2003 | 01:38 PM
Gripenfelter's Avatar
Why would you want to skip the valve springs?
You can get LT4 springs for $37 from paceparts.com
Old Jan 29, 2003 | 05:05 PM
LALT1's Avatar
ok how big of a pain in the rear is it to try and change the springs while the heads are in the car on a Z. Just imagining that it is a major pain.
Old Jan 29, 2003 | 05:43 PM
SDAKOVIC's Avatar
not really, you will need a air compressor,
hose and adaptor to fit in spark plug hole,
valve spring tool.
jasonduaine
Apr 1, 2015 08:09 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
