How bent is bent?
Old Jun 2, 2007 | 11:26 AM
z28 justin's Avatar
How bent is bent?
So I'm trying to check for bent push rods. I was laying them on our kitchen counter and rolling them, then looking for excessive amounts of light coming from under them. But they all seem to have a little unevenness. If I look in the hole on one end I can clearly see out the other however, does this mean they're ok?
Old Jun 2, 2007 | 12:17 PM
sandman63's Avatar
If you think there bent, replace em. There not expensive. Its better to be safe than sorry.
Old Jun 2, 2007 | 12:20 PM
Z28LT1_Just_Nasty's Avatar
I believe its $36 for hardened push rods. Just replace them.
Old Jun 2, 2007 | 02:55 PM
Projectz28's Avatar
Moderator
uneven = bent.... get some new ones.
Old Jun 2, 2007 | 03:04 PM
Any wobble when rolling=bent.
Old Jun 2, 2007 | 08:09 PM
z28 justin's Avatar
Ok, new rods it is. Thanks fellas. Next question... are these decent replacements?
http://www.compperformancegroupstore...Category_Code=
Old Jun 2, 2007 | 09:16 PM
96capricemgr's Avatar
I agree that replacements are cheap enough that you shoul;d just do that.
That said most countertops are just plastic laminate over particle board, not precisely flat by any means and particle board moves with the weather(humidity).
You would be better off with a thick piece of glass or something else straight and rigid.
Old Jun 3, 2007 | 12:24 AM
Joe B's Avatar
The comp Hi-Techs are one of the best......many guys don't seem to understand that there's a HUGE difference in a 30 dollar set of "Cheaply" hardened pushrods, and a GOOD set (like the Hi-techs) that have been designed to have minimum harmonics and awesome strength, and a "REAL" hardening process.. (summit racing has some decent prices on them).........Joe
Old Jun 3, 2007 | 03:45 AM
Z-RATED94's Avatar
If you want a good deal on some Hi-tech pushrods, stock lenght, 500 miles, send me a pm.
HibachiZ28
Nov 6, 2015 12:53 AM
CARiD
Sep 30, 2015 05:44 AM
detroitmuscle
Jul 31, 2015 04:21 AM
camaro81
East South Central
Jul 5, 2002 07:59 PM
tubby
Jun 6, 2002 12:19 PM
