How bad would it be...
.... to put some thick oil, like some Lucas addative thick stuff, to cover up a rod knock for a little while, just so I can drive the car untill the shop has room to do my motor swap?
I've already got another motor to swap my heads/cam over to with a new oil pump and new lifters. Is there any possiability that I could mess up the heads/cam doing this?
I'm not talking about going out and beating on the car, I just want to beable to drive it for a little while, I miss the lope of the cam the sound of the exhaust and just being in the car.
Re: How bad would it be...
If something more were to happen to that rod, it could ruin your whole day. OTOH, it might survive for a little while. It's a roll of the dice. If you drive it much you will most likely need a crankshaft.
I've got a whole new motor, crank and everything. That's why I just asked about the heads/cam.
zajones
Jul 30, 2015 02:18 PM
