How bad is it to not use thread sealant on head bolts?
Old Mar 3, 2004 | 08:06 PM
1loudz's Avatar
i cant even remember now if i used any or not. Unless it had some on the bolts i used i didnt. Honestly i had never heard that you needed to do this till now, and ive had my engine together for over a year now, with no apparent problems.
im kinda worried now...... should i be?
Old Mar 3, 2004 | 08:13 PM
It's not like you are going to rip it apart to change anything, so why worry about it? Just be alert in case you notice some symptoms.
Old Mar 3, 2004 | 11:53 PM
RicocheT's Avatar
I agree with shoebox.
Reason you use it is because the headbolts screw down into the water jacket of the block. they CAN leak but apparently yours don't so Id say your AOK
Old Mar 4, 2004 | 12:00 AM
Zachz28's Avatar
wait did you REuse your old head bolts? Say it aint so say it aint so
Old Mar 4, 2004 | 09:46 AM
1loudz's Avatar
new bolts, just no sealant
Old Mar 4, 2004 | 10:39 AM
Kryckter's Avatar
Some of those bolts will go into the coolant passage and some time you can get a coolant leak out of the cylinder head bolts. If you did not use any sealent and you dont see any leaks or milky oil then I would say your fine. But it is not required to take it apart and re-do it. It is recomended to put sealent on the bolts so if there is a next time I would put some sealent on tose bolts.
Old Mar 4, 2004 | 11:35 AM
pearlpurple's Avatar
Say if a guy was very worried about this and wanted to get sealant on the bolts,, could he take them out one by one put sealant on them and put hem back in to proper tourque??
Old Mar 4, 2004 | 12:00 PM
1loudz's Avatar
ya, what he said!
Old Mar 4, 2004 | 12:04 PM
1loudz's Avatar
so lets say, some coolant does start to go by the bolts.......... what's going to be comtaminated? would you get coolant in the oil? would it get into the combustion chamber?
Old Mar 4, 2004 | 12:48 PM
94_Z28_guy's Avatar
A small amount could at first get in the chamber (turned to steam?), more and it will be present in the oil also.
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Feb 28, 2015 12:02 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
