how 2 remove injectors?
Old Aug 18, 2010 | 07:07 PM
jackrat454's Avatar
Do I need to remove the fuel rail on my 96 LT1 to remove the electrical connector on top of the injectors?
I'm trying to check injector pulse with a noid light.
Thanks!
Old Aug 18, 2010 | 07:15 PM
ACE1252's Avatar
No need to remove the fuel rail. On the injector connector, there is a wire like lock across the connector. Push down on the wire lock, while holding it down, pull up on the connector. To reconnect it, just push the connector on the injector til you hear a click.
You can also hear the injectors working with a mechanic's stethoscope.
Old Aug 18, 2010 | 07:29 PM
RamAir95TA's Avatar
Yep, it's a piece of cake. Push wire, pull up.
Old Aug 18, 2010 | 10:15 PM
...from the cam removal guide on my Tech Page...
Originally Posted by shbox.com
Press in on the center of the spring clip. When you press in on the clip, it makes the sides bow out. You can then pull up on the connector and it should come off.
Old Aug 20, 2010 | 07:32 AM
jackrat454's Avatar
Thanks for the help!
CaptainObviousI
29
Apr 29, 2021 10:35 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Jul 4, 2005 05:00 PM
