hotcam w/ comp 918 beehive springs
Old Apr 17, 2008 | 03:04 PM
lt1s10blazer's Avatar
i tried searching and j/ got confused on what u need in a spring for what cam. i was j/ wanting to know if the compcams 918 beehive sprinlgs would work good w/ the the lt4 hotcam. if no, why not? thanks
Old Apr 17, 2008 | 03:27 PM
Shon Herron's Avatar
You need the springs, locks, retainers and locators.
I can ship all of that to you for $300.
Old Apr 17, 2008 | 04:57 PM
I've got everything already ordered, springs, locks, and retainers. don't know what locators are? j/ needed to know if they were a good combo
Old Apr 17, 2008 | 05:02 PM
The Engineer's Avatar
The 918s will work really well with the Hot-Cam. Also, the beehive steel retainers are the same weight as the titaniums.
WD
Old Apr 17, 2008 | 05:10 PM
Stl94LT1's Avatar
Springs sit on the locators. You can use the stock locators, but not a perfect fit.
Old Apr 17, 2008 | 05:49 PM
thank you very much for the replies, i am glad to hear they will work well..
Old Apr 17, 2008 | 07:59 PM
chevyowner02's Avatar
What about useing the stock locators with the crane 10308-1?
Old Apr 17, 2008 | 09:04 PM
stereomandan's Avatar
LT4 springs are MUCH less expensive, and proven to work with the Hotcam. You could have saved yourself a lot of money. The lobes on the Hotcam are very easy on springs.
Dan
Old Apr 17, 2008 | 10:01 PM
96' Formula WS6's Avatar
Dan
True, but I have heard that the LT1 valves are heavier than the LT4 valves. So the springs are rated to handle the LT4 cam but not with the stock valves. Correct me if Im wrong though because Im not positive.
Old Apr 17, 2008 | 10:26 PM
What I am saying is that the LT4 springs are proven for use with the Hotcam, even with 1.6RR's, in the LT1 with the stock valves etc...
The valves might be lighter on the LT4, but that would only make the springs even that much better for an LT4 application.
Dan
Old Apr 17, 2008 | 10:28 PM
when we spec'd the HOT cam springs, they were too close to coil bind for our liking. so we use other springs.
other benefits is less weight on the valve train, that is a good thing!
Noenav
Mar 1, 2019 07:38 AM
R@mpage
Apr 20, 2015 10:02 AM
95chwagon
Jan 13, 2015 09:19 PM
