HotCam Timing Chain question
I am planning on purchasing the hotcam kit for my bird. Im going to go with the GM timing set. Would I need an 'Extreme Duty Timing Set' or would I be alright with the regular LT4 set?
edit: Also, if I went with the Extreme Duty one, would it be preferable to also purchase the oversize Crank Sproket?
Re: HotCam Timing Chain question
The LT1 sprocket is undersize as compared to a SBC,as the General spected it that way to take some of the load off of the front cam bearing. It has enough load driving the water pump.
If ya are going to run an electric WP the "oversize"(same size as a standard SBC) will work,if ya are running the stock water pump I would go with the "standard" LT1.
The GM chain is made by Cloyes to the Generals spect.
Over 100k on my motor now with the hotcam kit in it, and the stock lt1 timing set. Its still going strong, and it gets revved over 6k frequently. Of course when I installed the hotcam kit in this motor back in 1999, it was a brand new LT1 long block on the stand from GM, on a so everything was brand new.
I dont advise what I do but I'm running the stock chain and gears on a 130k engine with the hotcam and spraying a 150 shot, runs like a beast. a double roller is over kill for a hot cam...
thats a bomb waiting to go off.
