Hotcam Dyno Numbers
Old Nov 9, 2006 | 08:18 PM
Steve0's Avatar
Hotcam Dyno Numbers
Well, I finally made a trip down to F-body Central (great shop for those in the Baltimore area) and put my car on the dyno. The car put down 322rwhp and 333rwtq on a Mustang Dyno. This is up from 278rwhp that I dynoed on a dynojet a few years ago with Macs, CAI and a magnaflow muffler. See the chart below:
The car is a '95 Z28 M6, 109,000 miles with the following mods:
Moroso CAI
Airfoil
Mac Headers
Gutted cat
Borla Catback (smallest opening plate)
LT4 Hotcam (218/228 .492/492 with stock rockers)
LT4 Valve Springs
LT4 Knock Module
Accel Optispark
MadZ28.com tune
I would say the car is running pretty good for what's done to it. While these numbers dont show anything revolutionary, I think they do show that the LT4 hotcam is a good performing cam at a good price. I daily drive my car, 200 miles a week and love it. Theres very little cam surge and the gas milage has remained pretty much identical to stock.
Old Nov 9, 2006 | 08:31 PM
GreenbeanZ28's Avatar
People will bash the hotcam all day and then some, but that sucker runs good and has run good for years.
Old Nov 9, 2006 | 08:33 PM
MeanGreen97Z's Avatar
Wow! That is a SOLID torque and hp curve. No break up at all. Car must be very well maintained. Excellent numbers for what you have done. I see you put that you have stock rockers. Possible you have 1.6s?
Old Nov 9, 2006 | 08:38 PM
Steve0's Avatar
Thanks!
The rockers are 100% stock. I didnt have an extra $200 to blow on upgrading them so I just reinstalled them when the cam went in. I believe stock is 1.5:1 stamped steel.
If I can find a cheap set of 1.6:1 roller rockers at a good price, I'll throw them in and see what it does. My budget is kinda tight right now though... I graduate from college in December and I'm saving up for a 4 banger to commute to work in.
Old Nov 9, 2006 | 09:30 PM
I bought the 1.6 roller tip rockers off of ebay. I'll let you know how they work out. They are only 68.95 new.
Old Nov 9, 2006 | 09:34 PM
96capricemgr's Avatar
I ran ProForm 1.5 full roller on a ZZ4 cam for almost 30K and before that on stock cam for 10-15K they are still in good shape and will endup on another motor one of these days. CAT is the only brand of rocker I would specifically avoid, bad bad things.
Old Nov 9, 2006 | 09:46 PM
lt11997's Avatar
A4 or M6?
My car put down 290 untuned with the mods in sig except CAI and 3.73's.
Old Nov 9, 2006 | 09:48 PM
Steve0's Avatar
M6, I should put that in the original post.
Old Nov 9, 2006 | 09:51 PM
ponchoV8's Avatar
At 109K miles, did you also have to replace the cam bearings? I would love to just do a cam and RR's, but at 160K miles I'm thinking too much hassle for an old engine.
Old Nov 9, 2006 | 09:57 PM
lt11997's Avatar
I did my hotcam at roughly 109,000 mi. The front cam bearing looked ok so I didn't bother changing them. This setup is only to have fun until I need a rebuild, then I will probably be going with a 383 and LE3 setup.
Old Nov 10, 2006 | 05:49 AM
Steve0's Avatar
No bearings were replaced. I suppose you could replace the front bearing with the engine still in the car, but I dunno if theyre supposed to be aligned in a special fashion... and if they are supposed checked for alignment, I dont think that is possible with the engine in the car.
Old Nov 10, 2006 | 06:47 AM
RE AND CHERYL's Avatar
I've been meaning to get over to F-body Central and check them out.
Those are good numbers for a hotcam on a Dynojet. The fact that you made those munbers on a Mustange dyno which are ususlly about 10% lower is awsome.
No. You can't change cam bearing with the engine in the car.
Old Nov 10, 2006 | 07:14 AM
526 SS 96's Avatar
SteveO: Congrats on the good #'s. I loved my old hot cam setup.
There was a thread no too long ago where members accused me of lying about my hot cam #'s. I did 345hp & 346tq, but I also had the: 1.6 RR's, m6, and it was on a dynojet. So your car is running very strong. Either way be on the look out for 'cantonracer' and 'bubba'. One of them swears they have seen a dyno atleast once, and the other is just plain stupid. They gave me a bunch of grief because my results conflicted with what they read elsewhere by other non users on the internet.
Old Nov 10, 2006 | 08:11 AM
Javier97Z28's Avatar
Moderator
Great #'s considering stock rockers... throw some on there when you get a chance and you'll probably pick up another good chunk of #.
Old Nov 10, 2006 | 08:16 AM
ABA383's Avatar
[QUOTE=RE AND CHERYL;4216552]I've been meaning to get over to F-body Central and check them out.
I've been using them for a few years now...Good people, prices, and a great in house tuner...Very knowledgable and a riot to be around...They're the reason I run what I run...
Good numbers SteveO...Did you make a 1/4 pass on the dyno? Thats a lot of fun!!!
--Alan
