hotcam, 503
Old Feb 2, 2007 | 02:08 AM
ajlew9428's Avatar
hotcam, 503
Im looking for the most streetable, fuel efficient, and cost effective cam. I have limited too the hotcam, and cc503. I think the hotcam would win the 3 categories mentioned above,and cost effective due to the fact that I already have lt4 springs, and SA rockers. As for the effective part. W/ mods in sig, what would be my hp, and tq gainsw/ hotcam, and w/ 503? Im just looking for people w/ similar setups with the hotcam, or 503 to post some times, or hp numbers. Also lookin for some rough estimates. What kind of power if I went hotcam, and what kind if I went 503.
Old Feb 2, 2007 | 05:43 AM
jkipp84's Avatar
When I had the 503, I got 326 SAE at the rear wheel (I have an A4). Very good cam, streetable, no problems. I recommend it.
That said, you can't go wrong with the hotcam either. It's a proven performance bang for the buck pkg. In terms of power, I don't think it'll be all that far off the 503.
Old Feb 2, 2007 | 10:54 AM
2000GTP's Avatar
The CC503 will make more power over the Hotcam. However, it is up to you if it is worth the extra cost to beef up the valvetrain a bit more.
Old Feb 2, 2007 | 10:59 AM
93redBirdMan's Avatar
i agree with 200GTP's post...
Old Feb 2, 2007 | 11:00 AM
buzz12586's Avatar
Was that with stock or ported heads??
Old Feb 2, 2007 | 11:24 AM
BUBBA's Avatar
CC 227 JMHO---Whatever you get make sure that the springs will handle the cam with good margin of safety, esp. with SA RRs.
Old Feb 2, 2007 | 05:13 PM
ajlew9428's Avatar
do you think ill be ok w/ lt4 springs and hotcam. I know max lift on the cam is what the springs max out at
Old Feb 2, 2007 | 05:21 PM
NJ-LE's Avatar
Smile
I think it puts you back to where people putting 1.6 rockers on the LT1 cam and spring set are. They are on the edge and as the springs fatigue they start losing power on the top with valve float. Why not buy the Hotcam spring set? They probably don't cost anymore than the LT4 spring did. Cheap insurance.
Old Feb 2, 2007 | 05:27 PM
CamaroSS8887's Avatar
Does the computer have to get retuned with those cams are will it run fine without a tune.
Old Feb 2, 2007 | 05:49 PM
2000GTP's Avatar
Anytime you put an aftermarket cam in, you should get the PCM tuned. The Hotcam is the exception, you can get away with a stock tune, but it is still advisable to get one. The CC503 will need a PCM tune.
Old Feb 2, 2007 | 06:10 PM
jkipp84's Avatar
Stockers..
Old Feb 2, 2007 | 10:31 PM
CamaroRacing12's Avatar
thats pretty damn good #'s..... making me want a cc503 more and more.... also look into custom grind cam's....they can make u whatever u want.... streetable with a lot of power.... thats my plan!
Old Feb 3, 2007 | 02:45 AM
hvyss's Avatar
I love my 503. But as stated before you will have to beef up the valve train. Your LT4 valve springs will not work with the 503.
HVY SS
13qtr
Oct 28, 2016 08:11 PM
MDZ28
11
Sep 24, 2015 09:15 AM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
stngh8r
West South Central
Oct 22, 2002 03:44 PM
