Hot weather issue
Old Jul 20, 2015 | 10:14 AM
  #16
DelSoto's Avatar
Re: Hot weather issue
Doubt it. If you want to play parts roulette (lol...I love that but can't claim it as mine....got it from Fred), you might replace the coil. Also check the spark plug wire between the coil and opti.
Old Jul 20, 2015 | 11:07 AM
  #17
Originally Posted by Xiantyl
So new icm still same issue lol , starting to think it's my optispark , could changing just the cap and rotor be enough since I have nk SES light ?
The heat soak problem affects the optical cam position sensor. That is located in the body (back 1/2) of the Opti. Replacing the cap/rotor will not replace the sensor. When the sensor fails, it may set DTC 16, and that does not turn on the SES light (assuming "nk" should have been "no").
Old Jul 20, 2015 | 11:49 AM
  #18
DelSoto's Avatar
I was going to tell him to scan again (which could reveal DTC 16), but at this point it feels like beating a dead horse. How many times can you give advice to have it ignored over and over before you give up.
Old Jul 21, 2015 | 05:42 AM
  #19
Xiantyl's Avatar
Wasn't ignoring your advice I stated I'm waiting until payday to purchase my aldl cable. Figured I could replace parts in warranty in the meanwhile and chance fixing the problem , now I do have a SES light now so I'm thinking its the optical sensor that is bad but I won't know for sure until I'm able to run a scan .
calaban
May 18, 2020 06:43 PM
Critter
Jul 7, 2015 08:33 PM
Drtryder
Apr 22, 2015 04:17 PM
91 Redd Sledd
Jul 18, 2002 08:25 AM
