Hot Start Issues on LT1
Old Sep 26, 2009 | 01:01 PM
Paul94Z28's Avatar
I have a hot start issue on my 94, it acts like it is flooded sometimes... I did install accel 30lb injectors and have heard these have issues sometimes. Is this the problem that they tend to have? Other than this, they have performed flawlessly.
Old Sep 26, 2009 | 01:59 PM
94Sleeper's Avatar
I had a problem with a leaky injector once and it had a hard time starting after I shut it down hot. When it did catch it blew a cloud of white smoke that smelled like fuel.
What you can do if you have a fuel pressure gauge is to monitor your fuel pressure after you turn your engine off and see if it bleeds down. If it does you have ether a leaky injector or a bad check valve. However given the symptoms it would likely be an injector.
Old Sep 26, 2009 | 03:29 PM
Paul94Z28's Avatar
Thanks, I do have a gauge and will check that out.
Old Sep 26, 2009 | 08:25 PM
jamesfs912's Avatar
Could be ICM. Possible cause when the engine gets warm.
calaban
May 18, 2020 06:43 PM
Gtpguy
Jan 26, 2015 04:50 PM
Britbilly
Jan 7, 2015 08:49 PM
Jul 4, 2005 05:00 PM
Hoodshaker
Aug 27, 2002 02:32 PM
