Hot And Cold Plugs?
Re: Hot And Cold Plugs?
A spark plug needs to hot enough to be self cleaning (burn off deposits) yet not be too hot that it causes the fuel/air mix to ignite before the spark plug fires. As you HP increases, you're more likely to pre-ignite your air/fuel ratio, therefore you run a colder plug than stock. There can be 6 or more heat ranges of plugs. I'm presently running two heat ranges colder than stock on my 10# blower car.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Drtryder
Apr 22, 2015 04:17 PM
armedtrigger
Feb 24, 2015 08:30 PM
Brake_L8
Jan 20, 2015 09:44 AM
