hot cam parts with cc306?
Old Nov 19, 2003 | 10:35 AM
meandmyz's Avatar
Will i be able to run a cc306 using the rr's springs and all from a hot cam kit, i mean are the parts good enough for it or should i just buy everything separate? Thanks
Old Nov 19, 2003 | 10:38 AM
Sweetred95ta's Avatar
Roller rockers, yes. Springs, no!!! Those springs are barely enough for the hotcam. I didnt even chance using the springs.
Benji
Camaro_Maniac63's Avatar
Hotcam springs are barely adequate for the hotcam itself, so you will need to buy better springs at least. The rockers and such, you should be able to use without any problems. Just check and make sure all the parts are in good shape (lifters, pushrods etc..). Good luck.
Old Nov 19, 2003 | 10:39 AM
97Camaro007's Avatar
no they are not good enough...the springs are good till .550 with the hotcam kit and with 1.6 rr's the cam is bigger than that.....buy new springs and the rocker arms will work fine
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
