hose with bleeder screw question
Old Mar 8, 2010 | 12:28 PM
fragglerock's Avatar
I have pinhole on the upper hose as see in this pic
http://shbox.com/1/bleeders.jpg
the hole is right beside where the hose is attached to the metal fitting, it looks like the part numbers are separate as far as the 2 pieces of hose that fit into each side of the metal tube, the pin hole is on the short hose on the right, am I able to get the old hose out of that coupling and put a new hose there or do I need that whole assembly?
Thank you
Old Mar 8, 2010 | 12:33 PM
camarorz28's Avatar
your talking about the end hose attached to the water pump after the bleeder fiting. as you can see its crimp on. i would say that the entire hose would need to be replaced.
Old Mar 8, 2010 | 12:39 PM
yeah, that's the hose, but the hole is right where it goes into the metal tube that the bleeder screw is in, can I take the hose out of that metal tube and just put a short hose between the bleeder metal part and the water pump? how do I get the hose out of the bleeder metal part?
Old Mar 8, 2010 | 12:57 PM
Thank you
The hoses can be replace individually. A Dremel and a cut-off wheel to slit the swaged collar and then peel it off. A new hose can be put on with normal hose clamps. Please post the year of your car for the correct hose information (a signature makes it easy).
Old Mar 8, 2010 | 01:05 PM
it's a 95 z28, sorry about that, dremel to cut the hose or the metal? Thnk you!
Old Mar 8, 2010 | 03:13 PM
Cut the collar and not into the pipe underneath.
http://shbox.com/1/heater_hoses.jpg
Old Mar 9, 2010 | 12:21 AM
camarorz28's Avatar
that helps me for something like that in the future thanks shoebox.
Chris Anderson
Jan 27, 2015 08:30 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
pologreen97z
Dec 2, 2014 10:42 AM
squarehead
Nov 21, 2014 08:02 PM
