Horsepower numbers low?
Old May 9, 2003 | 01:05 AM
FLII ME's Avatar
Just got the car tuned today at ARE, for some reason numbers are very low, I think the porting job on the heads 3-4 years ago was a poor one. Also, i think the LPE 219/219 cam is not the optimal cam for my car.
Here are the power mods:
LPE 219/219 cam 560",560"@112 LSA
ported heads
ported intake
58mm TB
3.73 gears
borla exhaust (cat back)
1 5/8" Edelbrock headers (no cat)
2600 stall TC
1.6 RR
Holley ignition
Trans Go shift kit
LT1 Edit tune
3-4 years ago when I had the cam/head package installed, car dynoed at 318hp/308tq, last night I got 308hp/320tq with ni sign of knock either. Car is much smoother now and driveability has drastically increased. Car feels like it pulls harder, will verify saturday at the track
Best time to date: 13.07@105.78
Saturday:??????
Anyone else experience low dyno numbers on a a4 LT1 with a cam/head package?
Old May 9, 2003 | 01:49 AM
rock1501's Avatar
Re: Horsepower numbers low?
ported heads
ported intake
58mm TB
3.73 gears
2600 stall TC
1.6 RR
Holley ignition
Trans Go shift kit
LT1 Edit tune
Saturday:??????
Ya Anthony my numbers are bad as well
293rwhp and 337rwtq
no headwork but I have an aftermarket cam.
I dont think dyno numbers mean a whole lot cause the LS1 boys kill me on the dyno and I kill them at the track
Old May 9, 2003 | 02:07 AM
FLII ME's Avatar
hey bud that is a healthy car you got there for those numbers, will you be going saturday? 12.52@109 with 293 horses? dude, your car is a beast...
Old May 9, 2003 | 02:39 AM
rock1501's Avatar
I will be there on Saturday to kick some Stang butt
I am not sure on this but I think a high stall T.C kills h.p a bit.
Thanks for the compliment I think you will get 12`s on Saturday
Old May 9, 2003 | 03:07 AM
Fastbird93's Avatar
ported heads
ported intake
58mm TB
3.73 gears
2600 stall TC
1.6 RR
Holley ignition
Trans Go shift kit
LT1 Edit tune
Saturday:??????
Wow, for ported heads and that cam and you only got 318 HP??? That's low to me. Really low.
Old May 9, 2003 | 08:27 AM
95blueformula's Avatar
Those combo's should be good for at lest 340rwhp plus minimum.
Heads must not have been done well at all.
Shot I make 286rwhp with no headers, cam or hed work.
Old May 9, 2003 | 08:46 AM
CANTONRACER's Avatar
Well, what type of dyno? Mustang or dynojet?
Any flow #'s on the heads?
What was the AFR WOT?
What type of tq? What STR?
Dyno #'s are great to brag about...but don't get ET's & MPH's...take my car, I dynoed 359/450 on a dynojet and ran those times in the sig....with some weight reduction, but not much.
Old May 9, 2003 | 11:07 AM
DR.ZED's Avatar
Dynojet.
A/F stabilized to 12.7 across the board.
Old May 9, 2003 | 11:08 AM
FLII ME's Avatar
Re: Re: Horsepower numbers low?
actually I got 318 3-4 years ago, last night I got 308 hp...
Old May 9, 2003 | 11:10 AM
FLII ME's Avatar
dynojet,
no flow #'s on the heads, most ;likely a stage one, i didn't know any better at the time, hence I just told him to port my heads...
AFR@WOT is optimized as it was tuned on last night using LT1 edit on a wideband dyno...
thansk for your help, I think the engine is tired as well as it has about 167,000 km and the heads were done poorly, also cam is not the proper one for my car..
Old May 9, 2003 | 11:19 AM
FLII ME's Avatar
Originally posted by DR.ZED
Dynojet.
Cam,
I think Andy will me my winter Beotch...
Old May 9, 2003 | 01:08 PM
DR.ZED's Avatar
Cam,
Okay... we'll both double fist him then.
See you tomorrow boo-boo.
Old May 9, 2003 | 01:13 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
wierd cam
lots of lift
little duration
doesn't favor exhuast
Old May 9, 2003 | 01:42 PM
FLII ME's Avatar
trey,
based on my mods, if you wer in my shoes what cam would you select? granted I know it depends on teh heads, but lets say on average ported LT1 heads...
glad to see your going to Cedar Point, let me know when your heading to Windsor,
Old May 9, 2003 | 01:53 PM
treyZ28's Avatar
trey,
I dunno, REALLY depends on goals, car and a multitude of of other factors?
stroke, compression, goals, how high you are willing to rev, what your heads flow and how they flow...
Xe 224/230 is a good off the shelfer
