A horrible, horrible thing has happened, and im afraid its as bad as it sounds
Old Sep 17, 2003 | 06:27 PM
1994Hawk's Avatar
Unhappy A horrible, horrible thing has happened, and im afraid its as bad as it sounds
Ok lemme try to catch my breath here, about 3 days ago my car started hesisating, and the idle was surging when hot, well it didnt really go away, or get worse until today. I went to pick up a friend from school, and on the way back my car is hesitating really bad and the temp is steady rising, well i pull into my driveway just as it reaces the red. I shut the engine off, and look at the car, i look under it and notice a little bit of coolant dripping, well i think maybe the coolant has been dripping on the optispark and making my car mess up, well i crank the car up, let it run, and notice the temp rises a bit, then i hit the fans, and it was going back down, so i turn off the car, check some fluids again, and i go to crank it, and THE WORST SOUND IVE EVER HEARD IN MY LIFE. It was an awful grinding sound that could have made the strongest man cry........im not too educated about what this could be, but im thinkin nothing good can come of this, it has to be very serious.....spun bearing, blown head gasket wtf happened???
Old Sep 17, 2003 | 06:32 PM
TreySpeed's Avatar
On permanent vacation
im going with over heated car = blown head gaset===> spun bearings or hydrolocked motor (if it kept running, i'm going with A)
time for a supercharged 396
Old Sep 17, 2003 | 06:50 PM
Compstall's Avatar
Find the source of the coolant leak and we can go from there.
Old Sep 17, 2003 | 07:11 PM
Fastbird93's Avatar
Could it possibly be the starter not fully engaging?? Was the motor fully turning over or did it not turn over at all??
Old Sep 17, 2003 | 07:59 PM
Javier97Z28's Avatar
Moderator
Is there any coolant left?
Old Sep 17, 2003 | 08:22 PM
TreySpeed's Avatar
wait, did the car start and make these grinding noises? or when turning and then it didn't start?
Old Sep 17, 2003 | 08:27 PM
gb95zconv's Avatar
If the waterpump went south and locked up you could be grinding the teeth off the drive gears for the pump....you need to see if the coolant is coming from the weep hole and replace the pump now if its bad.
Old Sep 17, 2003 | 09:35 PM
notstock4long's Avatar
Are you sure the car was off when you tried to start it again?
That does make a very bad sound. But did you have any coolant left, or was it all gone?
Old Sep 17, 2003 | 09:43 PM
HardcoreRM125's Avatar
Pop the hood, get someone to have their head by ( NOT AGAISNT ) the engine, crank it real quick, and have them determine where its from ... Im guessing that the head gasket went ... In which case id change the oil and see if its milky, if its ok , then id look elsewhere for the problem, and if the oil is milky colored, for the love of god DONT ruin a perfect shortblock ... Dont run it again untill you fix the leak , AND FLUSH it with some cheap .99$ oil
Old Sep 17, 2003 | 09:58 PM
ramair94ta's Avatar
check the coolant to see if theres any oil in it, water pump have have want and might have taking a head gasket with it. Hope its just the pump
Old Sep 18, 2003 | 01:31 AM
1994Hawk's Avatar
ttt
Old Sep 18, 2003 | 02:23 AM
Zack's Avatar
i was gonna ask the same thing, because that sound is just horrid
Old Sep 18, 2003 | 10:49 AM
1994Hawk's Avatar
Wtf of course i wasnt grinding the starter
Old Sep 18, 2003 | 11:35 AM
rage366's Avatar
well, if your flywheel has broken a tooth (or two), it'll make a really nasty sound.
Old Sep 18, 2003 | 11:37 AM
rage366's Avatar
oh, and also, if your car is overheating, NEVER just turn it off....
just cause you turn it off, it's still heating up, because now the fans are off...
leave it in the "on" position so the fans run.
