horrendous backfiring!
Old Jun 19, 2005 | 05:43 PM
TruDualed95Z's Avatar
I've been battling this problem for awhile now. I've replaced the opti, plugs, all wires, ignition coil and O2's. After installing the wires I disconnected the battery overnight inhopes the codes would clear and everything would run correctly (assuming something I changed would have fixed the problem) I don't have access to a code reader at this time. I'm aware that in order to find the exact problem I'll have to have the codes read, but until then has ANYONE had this same problem?
Any time I give it the slightest bit of gas it backfires. This leads me to believe it's running pig rich, but it does this (the backfiring) from the second I give the car gas after turning the ignition. The backfiring was so repetitive it lead me to think I plugged a wire in the incorrect firing mode, but as I installed the new wires I installed them one at a time (as I removed an old wire I plugged the new wire in its place)
Any ideas? What other steps can I take until I have access to a scanning tool?
Old Jun 19, 2005 | 06:34 PM
SUTTERERMAN85's Avatar
Re: horrendous backfiring!
check fuel pressure. a lean condition could be a causing backfire. just a though.
nick
Old Jun 19, 2005 | 09:09 PM
marshall93z's Avatar
Mine does it when I'm coasting and just BARELY touch the gas pedal. No clue what's causing it??
Old Jun 19, 2005 | 09:22 PM
Okay I drove it for 20 minutes and I suppose the computer completely corrected itself. It's pulling like a bat out of hell again!
Old Jun 20, 2005 | 11:17 AM
Canuck wita WS6's Avatar
So it just went away? You didn't do anything else to it(besides what you posted) to try and fix it? Or was this just after you replaced the plugwires?
Old Jun 20, 2005 | 11:20 AM
The wires were the last thing I replaced. I changed the plugs, O2's, coil and opti a couple weeks ago and the problem was still there. After leaving the car disconnected overnight it still ran bad yesterday, but once I drove it for 20-30 minutes the backfiring just went away and all the power came back.
Don't ask me...
Old Jun 20, 2005 | 02:49 PM
BRIAN93Z28's Avatar
were having the same problem right now, i have NO idea what it is! check out my thread. http://web.camaross.com/forums/showthread.php?t=376095
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Dzmaro
Jun 19, 2015 11:38 AM
Chet1185
May 10, 2015 09:24 AM
