hooking up with nitrous
Old Jan 13, 2004 | 04:49 PM
n20ta2's Avatar
I havent been able to make a full pass down the track on nitrous since I built my car six months ago,I cant spray off the line without seriosly spining the tires.What suspension mods do you guys suggest to help me stick off the line? I have a full 8 point cage boxed sub frame connectors and 28/11.50 et streets set at 17 psi. I was thinking of boxing the lower controll arms and adding 90/10 ratio shocks to the front do you think that will work? As it stands I cant hit the spray untill im like 10-15 ft out of the hole. Also, I havent been able to get bottle pressure over 700 psi because of the cold. What do you guys think it will run if I can stick the launch and use a bottle warmer, baseline is in the sig thanks.
Old Jan 13, 2004 | 04:52 PM
n20ta2's Avatar
dang I should have posted this in the n20 section sorry
Old Jan 13, 2004 | 05:30 PM
Josh-'04 GTO's Avatar
I don't see a torque arm in your sig. I think that would help the car "bite" harder off the line. A set of tubular/boxed control arms wouldn't hurt either. If the car is pretty much straightline-only, you could add an airbag as well.
As for the updated times, isn't the rule of thumb one tenth at the start being worth two tenths at the end? If you can shave a couple of tenths off your 60', you should be able to pull down a 10 sec pass.
Old Jan 13, 2004 | 10:01 PM
LPEdave's Avatar
Re: hooking up with nitrous
Originally posted by n20ta2
.... 28/11.50 et streets set at 17 psi.
First thing, get that pressure down! 12psi or so will get you much better traction...
Dave
Old Jan 13, 2004 | 10:06 PM
n20ta2's Avatar
Thanks guys I will try your suggestions.I will post my time next time I run at the track!
Old Jan 13, 2004 | 10:50 PM
QCKZ28's Avatar
what sixty foots are you pulling with the et streets?
jesse
Old Jan 14, 2004 | 12:16 AM
atljar's Avatar
Ditto on the ET street pressure. Drop it down to 12-13 psi and heat them hard. A torque arm which mounts anyplace other than on the tranny mount will also help a ton.
Old Jan 14, 2004 | 12:26 AM
S.J.S.'s Avatar
The LCA's and some brackets will help. Most people I know don't hit it till outta the hole anyway. I got a friend with a 02 SS with heads, cam and true duals running 10.8s on a 150 shot with DR's.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
jackpawt883
Sep 10, 2015 08:53 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
