Hooker LT vs MAC mids
Old Oct 26, 2004 | 11:08 AM
Bobsep84's Avatar
Hey guys, i am debating between the Hooker long tubes and the Mac mid lenghts. I know the Hookers have the most gain but they are kinda expencive. The macs are more what i can afford. Is there a big diffrence between the 2?
Old Oct 26, 2004 | 11:17 AM
LT1ponykilla's Avatar
Re: Hooker LT vs MAC mids
do a search!
Old Oct 26, 2004 | 11:22 AM
blaze309's Avatar
At first i wanted long tubes but after reading reviews and stuff over headers. I decided to get mac mid's. From what i read you'll get pretty much the same gains as longtubes but it'll be a diffrent feal through the powerband. Longtubes are supposed to take some low end torque and hit harder in the upper rpm's so i would suspect that mid's would be smoother throughtout i guess?
I'm going with mac's becasue i can still have emission hookups and all that junk and be able to lower my car and now worry as much about dragging.
I think im buying the mac's next week so i'll tell you how they are.
Old Oct 26, 2004 | 11:24 AM
30thannZ28's Avatar
I've had both sets that you wanted to know about and I sold the macs VERY quick. they leaked like crazy from every possible place including the collectors. And no it wasn't the gaskets or the bolts because I reused the same bolts (stage 8 locking) and the same gaskets (felpro 1406? I think) and the jet hot long tubes are FLAWLESS. No leaks anywhere and nice gains over the macs. Course I have ported heads now and didn't then...
BTW: The macs burnt my wires (2 of them). Jet hots aren't touching. Spend the extra $$$ on jet hots.
Old Oct 26, 2004 | 11:37 AM
Bobsep84's Avatar
How much do the Jet Hots cost and are they mids or LTs?
Old Oct 26, 2004 | 11:47 AM
94red's Avatar
I have had both and if you want more power definetly go with the long tubes. The macs give a very noticable power increase, give great access to the spark plugs, and don't scrape the ground. The hooker long tubes give a great power increase, scrape the ground frequently, sound awesome, and require a special y-pipe. The macs come with the y-pipe.
Old Oct 26, 2004 | 12:36 PM
Bersaglieri's Avatar
First search this subject up the rear. There are some 5+ page threads on it. But basically I was once in your shoes and figure if I was going to go through the trouble why not do it once and do it right. Spend a little extra and go the extra mile. My sig shows the route I went and simply put, a couple days after I put the Hooker LT's on, I raced a Ford Lightning SVT and won, THE END.
-Dustin-
Old Oct 26, 2004 | 01:42 PM
30thannZ28's Avatar
Here's a breakdown of what you'll need:
Jet Hot LT's=$550 w/o emissions and the 02 bungs already on
02 extensions (2)=$25 each
mufflex (or equivalent) y-pipe=$250
4" to 3" spacer=$25
welding for spacer to catback=$10-$20 depending on where you take it
new gaskets i.e. felpro 1406? (I think) and collector gaskets DO NOT USE THE SUPPLIED GASKETS UNLESS YOU LIKE DEALING WITH LEAKS.
new header bolts i.e. stage 8 locking or similar product
There you go. Make sure you get the headers to your specs i.e. with or without EGR or AIR holes/fitting. I removed both systems myself (costs nothing) and had them tuned out.
good luck!
Old Oct 26, 2004 | 03:40 PM
Bobsep84's Avatar
yea, im trying to stay emissions legal, so i need EGR and AIR connectors plus a high flow cat
GREEN3112
Feb 10, 2019 09:19 PM
RUENUF
Mar 13, 2016 03:37 PM
Devinfoote87
Sep 4, 2015 05:52 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
Z28amustangklr
Jul 18, 2015 11:05 AM
