hook up a LS1 air box to a LT1
Re: hook up a LS1 air box to a LT1
It's been quite a while since I've really chimed in, life goes elsewhere sometimes. Yes, I've done it myself, I personally used a LS1 radiator support that the Lid attaches to. I wanted a factory look. I have a cowl hood from VFN & I just had to do a lil trimming to one of the hood supports but that's hardly noticeable. Basically my lid kinda slips up into the scoop area @ the front of the hood when the hood is closed. Beyond that for me I basically used a couple of cheap hardware store couplers, some wire extensions for the IAT & some time.
My buddy Joel did a writeup on it. His username on here is JoeliusZ28.
Joel R DeVriendt.com » LS1 Lid & Radiator Support Install on 93-97 F-body
Been running that setup for a couple years now. I think you might have a hard time fitting it under a stock hood, i did quite a lot of trimming on mine. I would do it again though. Worthwhile performance improvement, and even though my filter probably doesnt have a *perfect* seal its definitely doing its job as ive cleaned the filter twice already. I would recommend using a cowl hood if possible so you dont have to cut so many things up. I dont like the look of cowls though so i did what i did.
I have a 2002 and i'm putting my LT1 in it so i already have the ls set-up on the car i did a search found what i need i was tired the day i asked n didnt search first sorry guys
95chwagon
Jan 13, 2015 09:19 PM
