Hood question
Old Jun 19, 2003 | 11:52 PM
meangreen95z28's Avatar
Hood question
I like the looks of the big block hood. But i am thinking about going to ram-air. I dont like the ram-air hood as much as the big block hood. Would the performance increase of the ram-air be better than a "nicer" hood?
Old Jun 20, 2003 | 12:14 AM
WheelmanZ28's Avatar
It hard to save how much of an acutal "performance" gain u are going to notice from a new hood.
I personnally like the Big Block Hood as well, however neither the cowl or the ram air are functional.
If ur looking for a nice hood for cooling, i personally would recommend a cowl hood. Good for disipating heat.
Old Jun 20, 2003 | 12:28 AM
silversupersport's Avatar
go for the looks, if you like the big block hood go for it. the ramair hood doesnt really add much for horsepower.
Old Jun 20, 2003 | 12:30 AM
FacelessZ's Avatar
There is a functional big block hood out there...but its over a grand...can't remember where I found it...
You're going to see losses if you go with any airbox kit that comes with a ram air hood because of heated incoming air from the hot engine...
Old Jun 20, 2003 | 12:34 AM
Thanks guys. Guess i'll save several grand to get a big block hood and new paint job.
Old Jun 20, 2003 | 12:37 AM
FacelessZ's Avatar
I have found big block hoods for $388....just for looks...
Old Jun 20, 2003 | 12:42 AM
Hoods are pretty cheap, but its that green to silver color change that will make me reach deep into my pockets.
Old Jun 20, 2003 | 12:47 AM
FacelessZ's Avatar
true enough
Old Jun 20, 2003 | 01:35 AM
Wild1's Avatar
www.rksport.com I believe they have a big block hood that can be cut open. Plus, you'll save about 35 lbs over the stock hood.
Old Jun 20, 2003 | 02:01 AM
m0nk's Avatar
If your going to save several grand on a big block hood and a new paint job, why dont u just use that several grand on some awsome heads, port the heads, or even supercharge it.
Old Jun 20, 2003 | 12:35 PM
Wild1's Avatar
The hood is $595...
http://www.rksport.com/prod_detail.p...03&view=detail
You can make it functional by grinding out the opening which they make strong enough.
Spend $150-$200 on paint.
For $800 max, you lightened up the front end by 35 lbs and have a functional big block hood.
novaiiman
May 15, 2016 11:36 AM
LT14LIFE
Feb 9, 2015 09:35 PM
CARiD
Jan 14, 2015 04:00 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
