Honest exhaust question......
here is the situation, i hate interior resonance(i'm pretty into aftermarket stereo systems)....and i daily drive my car pretty much only, rarely raced to much......what is going to be the gains of true duals vs. a normal cat back system....considering that either way the cats WILL be removed? this is a car with stock heads/cam........i just dont wanna take chances/deal with trueduals since im not really an expert. basically my question is...are true duals worth it for a stocker?
thnx guys
thnx guys
Yes, I beleive true duals are worth it, your predicament is getting them routed out thru the rear. I would use an X pipe design which can cut down on decibal's by about 4-6db, use two catalytic convertors and maybe a Hooker Aerochamber muffler on each pipe out the back. Your other alternative is to go with side pipes, but there goes the noise factor!
Otherwise, if you want something that's quiet, but aggresive on the outside, I'd get a Hooker Catback and some headers, probably will cost you the same as having somebody fab up true duals out the back for you, plus you'll gain a bit more with the headers/catback setup.
Hope this helps.
Hope this helps.
THATS PRIJME FOR FUN FACTOR LOL.....thats the loudest possible exhaust setup you could get....bullets are loud as hell.
Whats the diff in HP between headers with no cats and hooker aero chamber vs. headers w/xpipe and two mufflers?
If you dont want much noise dont do the Hooker Lt's x-pipe and bullets. Its a little loud. ( I love it). Your best bet would be Hooker Lt's and Hooker catback. Now if you can get the true duals to exit the rear of the car, which will cost more money, I would proably go that route. Also you did not mention that you where putting on aftermaket headers, are you planning on just adding true duals to the stock headers. If you are then I would not go that route. I would just get a catback.
If your just big into stereo stuff, I'd just get a regular cat back, maybe some headers down the line. I've never heard the Hooker Aerochamber exhaust, but it seems to be popular. Also you might want to look into Ravin's Z55 3" cat-back for our cars, it doesn't have that much interior resonance, and has a really clean and deep sound.
May 21, 2015 01:04 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
