homemade injector harness
Well, there's the deal. I have had a proplem with an intermittant dead miss for a couple months now, out of the blue I would lose 1, sometimes 2 cylinders. Then a minute or two later, they would come back to life. Well, last weekend, I lost 3, and they didnt come back to life... driving on 5 out of 8 is tough in a heavy caprice. Got a noid light set, and sure enough, a couple aren't getting power. wiggling them fixed it for a little while..
anyway, here's my plan. buy 8 injector connectors from the auto store. connect one of the wires from all of them to an "ignition on only" 12V source, and then make a nice little 8 wire bundle to the PCM, and connect my new wires in where the old wires were connected on the red plug I believe it is.
does this sound like a resonable idea? if so, does anyone happen to know what PCM pins go to each injector? I have been searching but have had no luck.
this is my daily driver, to and from work car.. I dont wanna spin a bearing or something from the off balance firing.
THANK YOU!
THANK YOU!
Re: homemade injector harness
i'd do the yard harness too...it's a PITA and not really worth the time/money involved in purchasing the tools necessary...just get a new harness.
to do this yourself, you'll need soldering wire, gun, wire, harnesses, butt connectors (solder connection, not crimp), punch tools, multi-meter, pins for the main connector.
I bought the fuel injector connectors and pin kit from Summit pretty cheap. I think it was a MSD kit.
http://store.summitracing.com/egnsea...08224&D=308224
I have no problem soldering a proper connection, and I have the tools already for that. I dont have pins for the main connector, so I will be cutting into the existing wires a couple inches out from the PCM (as I believe the wires usually break near the injector plugs).
fantastic link. they run about that much EACH at autozone. I'll overnight them.
carguyshu
Jan 22, 2017 11:19 AM
stockssn2o
May 25, 2015 08:54 AM
CobraEatr
Jul 23, 2002 06:32 PM
