homemade fan switch
Re: homemade fan switch
The advantage is to turn the fans on whenever you like. Here's a quick, simple wiring diagram that us 95 guys can use. Key must be in the ON position for the fans to work.
http://www.worldisround.com/articles/12201/photo28.html
Originally Posted by bowtiethunder
RamAir95TA, ain't there 3 fan relays so which 2 do you use? Will the computer still turn the fans on when the switch is off?
And yes, the PCM will still turn on the fans when the switch is off.
carguyshu
Jan 22, 2017 11:19 AM
