Homemade CAI???
Homemade CAI???
does anyone here have some instructions or a website to look at to get an idea on how to make a CAI for my 95 z28? I am thinking about getting a CAI, and have heard that making a homemade one is about as good as a store-bought one but loads cheaper. Thanx
Jeff
Jeff
Originally posted by 94zLT1
cut off the bottom mud gaurd under your air box..then cut away untill you see filter
Originally posted by Antz97ZNJ
I would imagine it to be a real pita to make, Even though ive read here for years about guys makin them. Id save up the hundred 170 bucks or so and get a good moroso system
. I could bet anything that my setup flows better than anyone on the market.
This is really simple, anyone with even very basic mechanical skills can do this. I built mine out of 4" PVC and built a homemade RAM air scoop for it as well. It probably took about 1 hour to built it (because I had to bend the PVC pipe to get the 4" to fit properly on the radiator shroud by heating it) and then I sealed it with RTV and left it to dry overnight before installing it. I only spent about $70 total for everything, so it is definitely worth instead of paying $200 for something that just looks fancier.
thats hillarious that you would say that....stop nig rigging your car and go with a proven performance mod like mine SLP CAI
sweet bro...and you even dynoed it...wow...did you see that 1-3 increase in HP (if even the CIA accounted for it) All im saying is it is a sure fact that performance mods from performance companies deliver results...when you start foolin around with weird **** you end up breaking LT1's (not in this cai case but in general)...chill out hombre.
. Half the people on this board have custom CAI. Get out of here and go to another board.
wow i think the babies diapers need to be changed...
