Holy exploding lifters
Old Feb 28, 2007 | 10:23 PM
jsetzer's Avatar
So what potential damage am I looking at? Rest of the lifter was not in the hole, so Im hoping its in the pan
Cam lobe feels smooth, but I know I need to pull it. Prob need to pull the head and check the valve too.
What else?
Old Feb 28, 2007 | 10:40 PM
I don't see how the cam could have survived without serious damage. Bits and pieces could be anywhere. I would have to go through the whole engine to be sure.
Old Feb 28, 2007 | 10:49 PM
Javier97Z28's Avatar
Moderator
Cam is most likely trashed... mine was hopped on the cam lobe a few times after bending a pushrod and trashed the cam.
Old Feb 28, 2007 | 10:56 PM
Critter's Avatar
omg what brand are those?
Old Feb 28, 2007 | 11:08 PM
jsetzer's Avatar
Just some oem ones.
Arg I don't have the time/money for another motor.
Old Feb 28, 2007 | 11:14 PM
Originally Posted by jsetzer
Just some oem ones.
I guess you can pray, then. That's a pretty nasty thing to happen.
Old Feb 28, 2007 | 11:17 PM
SS RRR's Avatar
Just some oem ones.
Nothing was said about having to replace the engine. Just going through it to get any pieces out so you don't have to spend the time/money on another engine.
Old Feb 28, 2007 | 11:20 PM
JP95ZM6's Avatar
If it makes it more fun, think of it as searching for diamonds in your engine. Any little piece you find could be worth thousands of dollars!
jsetzer's Avatar
Its the price we pay.
If nothing else this horrific event got Shoebox in one of my threads.
Old Feb 28, 2007 | 11:21 PM
jsetzer's Avatar
I'm more worried about any shavings rather than large pieces. (those are easy to get out)
Old Feb 28, 2007 | 11:32 PM
SStrokerAce's Avatar
I wanna know what caused it to do that? Could be a lot of things but what else in there was FUBAR?
Old Feb 28, 2007 | 11:38 PM
jsetzer's Avatar
I've been chasing something for quite a while, thought it might be valve float. I think a year of abuse did it.
The lifter was below the guide and has spun some. The guide was still under the spider piece and the other lifter still in place.
Old Feb 28, 2007 | 11:44 PM
seawolf06's Avatar
Then there must have been plenty of warning signs.
Old Feb 28, 2007 | 11:50 PM
jsetzer's Avatar
Not really, just about everything I have read here about lifters always says its the springs not the lifters.
Old Mar 1, 2007 | 02:03 AM
'94 Bad A Z28's Avatar
What else?
Your cam prolly looks like this:
Your rockers prolly look like this:
And your pushrods prolly look like this:
Then you prolly have little pieces of lifter scattered about under the spider in your intake and pieces getting lodged in your oil pump/pickup which will lead to a spun rod bearing which leads to a scared crank and a full rebuild... trust me I know. Tear the motor down completely to be safe.
