Holley versus ASM 58mm TB
Old Jun 21, 2006 | 10:32 AM
1BadBrd's Avatar
ASM rates there 58mm at 1030 cfm's does anyone know what Holley rates theirs?
Old Jun 21, 2006 | 10:41 AM
Re: Holley versus ASM 58mm TB
The flow rate is governed primarily by the diameter of the throttle bores. Smoothness of the bores, diameter and thickness of the shaft and blades, taper or "airfoil" affect in the bores will make some very minor differences, but "flow rate" should basically be the same.
And, a flow rating it meaningless, unless they also tell you the pressure loss at which they measured the flow.
Old Jun 21, 2006 | 10:52 AM
1BadBrd's Avatar
i was curious if the design or quality of the product would differ in the cfm ratings, since ASM was a bit more expensive.
Old Jun 21, 2006 | 11:46 AM
jerminator96's Avatar
AS&M is always going to be more expensive than Holley, whether your talking about a set of Hooker Supercomp LT's v. AS&M LT's, or throttle bodies or anything else.
Unless you are building a max effort race engine I doubt that the Throttle body is going to make a difference, not noticable anyway.
$.02 by Jeremy
Old Jun 21, 2006 | 12:33 PM
hosspwr94's Avatar
I had a holley on my last LT1 and it was rated at 1000 cfm, i think the rod in the asm is thinner, I believe that is the only difference.
Old Jun 23, 2006 | 09:28 PM
Josh'95Z28conv's Avatar
On page 3: http://web.camaross.com/forums/showthread.php?t=456977
Old Jun 24, 2006 | 03:37 AM
bunker's Avatar
Holley looks like a quality piece and is one, I haven't had problems with their blades as many state, you just have to find a sweet spot I guess, if you notice yours binding just turn the idle screw open a bit so that you don't hit the bind spot, but I mean honestly no probs here, and it's the best looking one IMHO
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
95craz28
11
Sep 12, 2015 07:47 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
