Holley TB worth The $$ on a ported Intake?
Old Jun 16, 2003 | 12:30 PM
AENIMA95z28's Avatar
I just got a real nice lookin 58mm ported Intake, i dont have a 58mm TB yet and i was lookin at the Holleys, They are real expensive though so im wondering if its worth it. It does look good but will it give me and HP gains at all? Hows teh BBK TB compared to the Holley ?
Old Jun 16, 2003 | 01:55 PM
n2ceptor's Avatar
If you check the Advanced Section, ther is a thread tallking about this subject......
Old Jun 16, 2003 | 01:57 PM
chevyboy_z28's Avatar
ive heard of some people having problems with the holley and switching over to the bbk?
Old Jun 16, 2003 | 02:01 PM
turbo_Z's Avatar
yeah i have also heard bad things about holley... blades stick or something to that affect. they sure look nice but the quality just isnt there.
Old Jun 16, 2003 | 02:05 PM
so what do you all recomend ? BBK ? - will i see any HP gains ?
Old Jun 16, 2003 | 02:35 PM
the BBK doesnt come with a built in airfoil, do you thinki should get one ?
Old Jun 16, 2003 | 02:42 PM
I have a Holley 58mm TB.... not very happy with the quality (and I bought it back when it was only $350). There was an excessive space between the blades and the body, and the throttle stop lever was not fixed firmly to the cable quadrent, altering the return point. I fixed it with a lot of work, and it seems better now, but for the $$$$ you shouldn't have to fix it.
I temporarily used a borrowed BBK 58mm while I was working on the Holley, and it was fine. I don't remember it lacking an air foil... in fact it was the TB George Baxter used on his 9.04@155mph pass, so I know it was "good".
The shop that does my work recommends the Accel/LPE unit.... but its even more expensive than the Holley.
Old Jun 16, 2003 | 02:47 PM
RUFFIDLNZ's Avatar
I had two different Holley TB and they do look great, and neither one of mine stuck. The only problem I had was the throttle cable didnt fit into the little hole at all. The hole was too big and the weight on the end of the throttle cable would just wobble and actually started fraying the cable. Since my motor is down for some upgrades I sold the Holley and bought a BBK. I have a friend that has one on his and it works great so this is why I went with the BBK.
Old Jun 16, 2003 | 02:55 PM
im convinced, BBK it is
Old Jun 16, 2003 | 03:56 PM
mojo's Avatar
Save your $300-you don't need a 58mm-I went from a 52mm BBK to a 58mm Holley-a waste of money-I wouldn't go bigger than 52mm unless you are going to stroke or SC it.
Old Jun 16, 2003 | 04:31 PM
got_hp?'s Avatar
agreed......unless youre putting down 450+ at the wheels..........a 58 probably isnt necessary.
Old Jun 16, 2003 | 04:34 PM
Definitely... .with my setup (381ci, 7,200rpm solid roller, 500HP) the TB supplies enough air at only 77% open, right from the engine dyno testing. Open the TB any further, and the air flow does not increase. Could have got by with a 52mm, if I was only looking at the NA data.
Old Jun 16, 2003 | 04:46 PM
dynomight's Avatar
Just had the new engine built. Originally had the holley installed, and the builder went to the bbk. Apparently an issue with blades not closing or opening to a full position. I would recommend bbk.
Old Jun 16, 2003 | 04:52 PM
Perry93TransAm's Avatar
I had the exact experience, I bought a BBK for my 93 and I had to do some serious rigging to get it to work, first off the throttle would only open up halfway and the TPS would not adjust right unless I almost turned it 45 degrees from its bolted down position, the instructions said "slight " TPS adjustment may be needed but 45 degrees???!!!?? I even went and bought a new one and zeroed the computer and still it needed major adj. The Throttle cable as I said befor needed shortening and the casting shift was very bad. I bought a Holly and it worked like a charm!
Old Jun 16, 2003 | 04:55 PM
so we have mixed thoughts with the TB's, well i figure if im gonna spend all that money on a new TB anyway why not get the 58, plus my intake is ported for that. Anyways wouldnt wanna have to buy a new one a few years from now when i do got the HP
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
