Holley TB guys...
Old Oct 8, 2003 | 11:38 PM
S.J.S.'s Avatar
Holley TB guys...
I'm gonna be bolting on my Holley 52mm soon and I heard that you had to make somoe adjustments to it. Is that right???
Old Oct 9, 2003 | 12:14 AM
Lisa33's Avatar
Only a little adjusting on the TPS sensor, think it was described in the manual.
Old Oct 9, 2003 | 12:45 AM
S.J.S.'s Avatar
What manual was that??????
Old Oct 9, 2003 | 02:33 AM
Zeueses 97 RamAir's Avatar
trust me
I have had the tb on for a year now yes big adjustment to tps....
You have to get the idle correct and then the voltage above 4.22 or it will throw a code 122 low voltage to tps if you need help call me 972-824 0793 you have to drill the tps holes wider and then play with the adjustments. Angelo
Old Oct 9, 2003 | 03:04 AM
S.J.S.'s Avatar
Thanks myman. I appreciate the help. You will get a call from me. Probably in like 2 weeks when the motor goes in.
Potent77
Mar 16, 2022 12:13 AM
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95craz28
11
Sep 12, 2015 07:47 AM
