Holley TB guys...
trust me
I have had the tb on for a year now yes big adjustment to tps....
You have to get the idle correct and then the voltage above 4.22 or it will throw a code 122 low voltage to tps if you need help call me 972-824 0793 you have to drill the tps holes wider and then play with the adjustments. Angelo
RUENUF
Mar 13, 2016 03:37 PM
