Hole in radiator - running hotter?
Old May 11, 2004 | 02:57 PM
sabre81's Avatar
i had a hole in the plastic part of my radiator, i patched it but its not totally airproof. Could this make my car run hotter by letting air into the system? note. im not losing coolant, radiator is full.
thanks
Old May 12, 2004 | 08:47 AM
sabre81's Avatar
ttt
Old May 12, 2004 | 09:11 AM
Coolant will boil sooner at a lower pressure. The system should be sealed and capable of the proper pressure so it can work efficiently.
With a hole in the system, it will try to draw in air when it cools down.
Old May 12, 2004 | 09:50 AM
95camaro z28LT1's Avatar
were u leaking radiator fluid when u had the hole. was it a good size.
i am just curious because i have a somewhat of a similar problem. i also saw the same problem on a friends 99z28.
is it by the battery down a little bit?
anyways give a reply or a pm. i live in west seneca. do u hang out w/ the ubrf people.
edit- also forgot to ask, what did u use to patch it.
calaban
May 18, 2020 06:43 PM
edman
Jan 22, 2015 02:45 PM
owen66
Nov 30, 2014 04:21 PM
