hmmm i think i just messed up big time..jethot slipfit tube...read
Old 01-05-2004, 09:03 AM
glennxx1's Avatar
thought i was done basicly, i hooked everythingb ack up, bolted motor mounts on etc etc boltedsteering knuckle back up, put plugs in, ran wires,...now im tryin to get this slip fit in with hte header bolted up....wondering if its even possible...did any1 get it on when the rest of the header was bolted up? need any info...ty alot--
glenn
glennxx1 is offline
Old 01-05-2004, 09:23 AM
jay g's Avatar
yes i bolted the drivers side header on then put the slip tube in, it is a very tight fit but it will go, just keep working the tube in and out to wear some of the coating off, i also used a thin layer of high temp silicone, this seemed to help by acting as lube for the tight slip joint,
i didnt need to remove my steering shaft even,
jay g is offline
Old 01-05-2004, 09:26 AM
GetaZforgetGT's Avatar
That's the only way to do it in my opinion.
I had to sand mine down to remove some of the coating from the end of the slip pipe so that it would fit in.
You don't want to go crazy because it needs to be a tight fit.
It was really hard to get it to go in but I don't have a leak.
GetaZforgetGT is offline
Old 01-05-2004, 09:30 AM
glennxx1's Avatar
ok im extremely happy to hear that, i think im going to use some soap to try to get her in...ive already sanded
glennxx1 is offline
Old 01-05-2004, 11:36 AM
simple's Avatar
if you have the driver side header already tightened down, loosen it up some to allow more room/play to maneuver the slip fit primary into place, then tighten it down completely after its in...
simple is offline
bunker
01-30-2016 08:09 PM
09-18-2015 03:46 PM
NewsBot
08-03-2015 02:40 PM
Louey
Pacific
07-27-2015 09:58 PM
Boss002
07-09-2015 03:33 PM
Quick Reply: hmmm i think i just messed up big time..jethot slipfit tube...read
