Hitting up the dyno
Old Sep 4, 2008 | 04:49 AM
95ltslow's Avatar
So i'm going to the dyno next week after my cam is installed. Just curious as to what i should be expecting as far as whp/tq and maybe a track time. Car
is a 95 lt1 6spd camaro. It put down 262whp/285tq with just hollowed cats.
Current mods-
k&n cai w/ tb air foil
jet hot long tube headers no cats, no egr
custom y pipe with dual cutouts to a borla exhaust
spec stg. 2+ clutch w/ short shifter
cc502 w/987 springs, seats, locks and ti retiner
comp cams 1.6 sa rr's
fresh rebuild on the 10 bolt with 3.73s
replica zr1 rims 275/45/17 nitto 555r's in the rear and idr the size up front
Old Sep 4, 2008 | 05:40 AM
NightTrain66's Avatar
6 speed car with stock heards and CC 502 cam, I would guess 320 RWHP.
Track times are all about 60 ft times and how well you can shift. A 2.10 60 ft time will get you a 13.1 1/4 mile ET and a 1.70 60 ft will get you a 12.3 1/4 mile ET.
Lloyd
Old Sep 4, 2008 | 07:01 AM
95ltslow's Avatar
From what I understand i though the cc502 was a slightly larger cam the an lt4. Ive seen and lt1 with an lt4 cam with supporting mods putting down 340whp all day. I was expecting more then 320whp.
Old Sep 4, 2008 | 09:05 AM
slomarao's Avatar
I'd say around 335rwhp. 340 rw would be pushing it. Who did you tune?
Pick up a used 52mm TB and a crank pulley. The two should be good for another 10rwhp. If its not tuned yet you need one badly.
Old Sep 4, 2008 | 09:35 AM
95ltslow's Avatar
It untuned. I was gonna go with a mail order then just fine tine from there. problem is finding someone to has the software to tune an lt1
Old Sep 4, 2008 | 12:36 PM
96' Formula WS6's Avatar
No its not a problem at all, there are plenty of places. The most common for mail order tunes are madz28 amd pcm for less. They do great work
Old Sep 4, 2008 | 01:01 PM
slomarao's Avatar
I would go with either Bryan at Pcm4less. or Madwolf. I use pcmforless, they nailed my car dead on. My hp and tq curves are flat ramps up. Perfect.
Getting the tune could or may net 5-25hp depending on many variables.
Get one before the dyno or you may end up very unhappy.
Bryan has a program where he will send you a tuned pcm for your year. You will pay a deposit on it and then once you install it you send back your old one for a deposit refund. I really like it. Leaves you with no down time.
Old Sep 4, 2008 | 01:06 PM
EnFuegoZ28's Avatar
How many miles on the motor? Did you have it rebuilt before the cam install?
Old Sep 4, 2008 | 05:23 PM
95ltslow's Avatar
It has 97k. Doenst burn a drop of oil. Been maintained well since day 1. Have pretty close to every reciept for everything ever done to the car. I am the 3rd owner
Old Sep 8, 2008 | 07:49 AM
95ltslow's Avatar
Any ideas on breaking everything in? just drive normal for a few days gradually bringing the rmps up more and more?
Old Sep 8, 2008 | 08:29 AM
<Puck>'s Avatar
Hydraulic roller cams dont need a real "break-in" like old flat tappets. I just do a quick oil change after the first 10 minutes or so of it idling.
As for power, I would say 320, 330 tops if the tune is nailed. I don't see 340 without head work and a 502...
Old Sep 8, 2008 | 09:11 AM
95ltslow's Avatar
^alright thanks alot. What else would you considering doing for some extra hp. I wasnt looking to do nething internal besides the cam. For now just bolt ons.
tdigger9899
Sep 7, 2015 10:56 AM
Greg88
Aug 24, 2015 07:59 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
