Hissing when turning motor over by hand
Old Oct 22, 2005 | 05:49 PM
Demus's Avatar
Just getting ready to start the engine after heads+cam work and a long list of other things. I turned the engine over by hand to make sure everything was good. There was no mechanical binding, but there was a hissing, like compressed air escaping. Everything (and I mean everything), was torqued to spec. Is this normal? I thought the cylinders should hold the pressure in for a bit longer, ala, leak down test.
Old Oct 22, 2005 | 06:24 PM
Dave89IROC's Avatar
Re: Hissing when turning motor over by hand
no, thats normal, they hold pressure fine dynamicly(moving/in use) but they are in no way air tight
Old Oct 22, 2005 | 07:17 PM
LJ93Z28GM's Avatar
That is normal, just start it already and give us some good news. Hope all goes well.
Old Oct 22, 2005 | 11:32 PM
ChevyTuffD.A.'s Avatar
If u are turning the motor over by hand then it will hiss. There is air in the cylinders and when u are turning it over u are opening the exhuast valves and air is going out. Trust me its fine. Peace, Dustin.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ro2207
Dec 4, 2014 06:18 PM
formula79
26
Aug 5, 2002 12:21 PM
